Bluetooth phone detection problem
Old Jul 8, 2004 | 11:13 AM
qali's Avatar
Has anyone has a problem with the TL not detecting their bluetooth enabled phone? I have been using my T637 without problems for a month. The past 2 days, when I get in my car (with my T637 and BT enabled), the TL doesn't detect it. Normally, if I try to turn BT off on my cellphone (while in/near thte TL), the phone won't let me . It will say "BT is busy". But the past 2 days, it just lets me. This makes me think there is a problem with the TL BT, and not my cellphone's BT.
Anyone with any ideas? I tried doing a search in the forum.. nothing.
Old Jul 8, 2004 | 11:26 AM
MARVE37's Avatar
Just a thought.. Computers..You may want to clear the settings (reboot) in the TL and pair up again from start.
Old Jul 9, 2004 | 09:21 PM
qali's Avatar
how do you "reboot"? My phone won't pair anymore.. the TL won't detect it.. but, I know the bluetooth on my phone works, because I can exchange pics and such with my friend's BT phone. So, how does one test or reset the BT on teh Acura?
Old Jul 10, 2004 | 09:26 PM
qali's Avatar
well, just in case anyone else has this problem....
I took out the fuse for the ECU (found in the fusebox under the hood) and put it back in. That was what I thought a "reboot" would be. NOTE: you should know your radio code. You WILL need it. After that, I ran thru phone setup and it found my phone, no problem.
Prior to the above, I tried deleting the phone profile, and re-adding/pairing it, but it wouldn't detect my phone. It timed-out (as the prompts says).
Hope this helps someone.
keywords: bluetooth detect reboot restart redo pairing BT
Old Jul 19, 2004 | 05:54 AM
smoore's Avatar
You should check and see if your phone is visible. You may have inadvertantly changed your Bluetooth settings and if the phone is not visible, then the car can't find it.
MilanoRedDashR
38
Sep 28, 2019 09:13 AM
Sep 17, 2015 09:01 PM
mgbe11
1/2G MDX (2001-2013)
Sep 15, 2015 07:53 PM
brandnewcolony
Sep 12, 2015 10:39 AM
ivegotthenav
Sep 11, 2015 07:51 PM
