Bluetooth phone delete?
Old Apr 27, 2004 | 09:05 AM
tpark's Avatar
Question Bluetooth phone delete?
How do you delete the bluetooth phone that has been paired without deleting the phonebook entries? Please help. I could not find the command that deletes just the phone. "Clear" command deletes the whole entries.
Old Apr 28, 2004 | 01:35 AM
mobilezen's Avatar
Does the manual say anything about it?
Old Apr 28, 2004 | 06:34 AM
smoore's Avatar
You go into phone setup and and then say delete. It will ask which phone you want to delete.
I have had two phones paired and deleted both phones. The phonebook was still intact. The phonebook appears to be completely separate from the pairing of the phones. When I repaired the phones the phonebook still worked for both phones.
Hope that helps.
Old Apr 28, 2004 | 09:51 AM
rets's Avatar
Moderator Alumnus
Thumbs up
Hope that helps.
This is good one.
Old Jun 14, 2006 | 04:31 PM
reclark5's Avatar
4th Gear
Old post, but looking for a little help. I tried deleting an old phone and used the above instructions. But the phone will not delete, it sends me in a continuous loop - 'do you want to delete', I say yes, it then asks to 'say ok to confirm delete', i say OK, then is asks 'do you want to delete' yes, and then 'say ok to delete'. It is a continuos loop. I tried to clear everything, same thing. Any ideas? Thanks
Old Jun 14, 2006 | 05:39 PM
HiTEC's Avatar
You can also press the phone button and say "Help"
It will guide you
Old Jun 15, 2006 | 07:50 AM
reclark5's Avatar
4th Gear
I called the support line at handsfree and figured it out. You need to cycle through the commands about 3 times. So you will end up saying yes and Ok to delete 3 times each. It seemed very odd the first time, I did not have enough patience.
BTW, it will be the same process for clearing.
Old Feb 24, 2007 | 01:39 PM
johnrieb's Avatar
6th Gear
It takes perserverance, and you have to be quick. I think any delay at all will cancel the action and send you back to the last prompt. Thanks to you guys, I just did it on my '06 loaner, and it worked! Acura owner for less than a week, and love my new '07 TL with Navi! Thanks!
mlody
Dec 4, 2019 02:11 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
DerrickW
Nov 15, 2015 05:52 PM
SUPRMN84
Oct 7, 2015 09:46 PM
