Bluetooth locked
Old Jan 17, 2008 | 09:07 AM
BRR11's Avatar
Bluetooth locked
I just purchased a 05 TL 6sd and I was trying to get my blue tooth going and it says to enter the unlock code and I don't have it, Is there a way to reset this with out going to the dealer? Help Thanks
Old Jan 17, 2008 | 10:26 AM
S PAW 1's Avatar
I believe what you are saying is that the previous owner enetered a passcode, which needs to be entered in order to use the HFL (hands free link). If that is true, the HFL will say" the system is locked, what is the 4 digit passcode?"
If that's the case, the dealer needs to cancel the passcode. He may be able to do this over the phone.
Old Jan 17, 2008 | 11:46 AM
Will Y.'s Avatar
Registered but harmless
Originally Posted by BRR11
....it says to enter the unlock code and I don't have it, Is there a way to reset this with out going to the dealer?
Possible answers in order of increasing degree of PITA:
1) Try "1234" for the code.
2) Do a search of the threads here (using "code" and "bluetooth"??) -- I think there were a couple of threads on this problem a year ago or so.
3) Contact former owner
4) See dealer.
Welcome to AZ, and G/L!
Old Jan 18, 2008 | 01:32 PM
jzacuto's Avatar
Hmmm... Just wondering... Can you get to the System menu? If you can, try "Clear" to reset the system.
Otherwise I THINK I read somewhere on AZ about how to re-initialize the entire BT system, but I don't recall how.
Old Jan 19, 2008 | 10:03 PM
handy911's Avatar
I am sure I read in the manual how to reset the passcode
Old Jan 20, 2008 | 09:13 AM
smoore's Avatar
Handy911 is correct, at least for the 08.
Press and release the talk button and say System. The response should be "System options are setup and clear". Press and release the talk button and say "clear". The response should be "This process will clear all paired phones, clear all entries in the phonebook and clear the passcode. Is this what you would like to do?"
Press and release the talk button and say "yes". The response should be "Preparing to clear all paired phones, all phonebook entries, and the passcode. This may take up to 2 minutes to complete. Press and relase the Talk button. After the beep, say "OK" to proceed, or say "Go Back" or "Cancel". "
Press and release the talk button and say "OK". Eventually the response should be "System has been cleared. Returning to the main menu.".
I hope that works in the 06.
Old Nov 3, 2009 | 08:39 PM
jc-tl's Avatar
Hi, I recently bought a 2006 TL and have the same issue. The system is locked and even if I try to say "system", it does nothing until I enter the passcode. I tried the obvious ones, no love.
I'll search around in here for the procedure...
Old Jul 15, 2016 | 07:58 PM
Nick Pippy's Avatar
Did anyone ever figure this out?
[QUOTE=jc-tl;11461602]Hi, I recently bought a 2006 TL and have the same issue. The system is locked and even if I try to say "system", it does nothing until I enter the passcode. I tried the obvious ones, no love.
I'll search around in here for the procedure...[/QUOTE
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
