Black Screen On Navigation
Old Jun 3, 2018 | 06:11 PM
Refridgator's Avatar
5th Gear
I recently purchased an 06 TL, and was told that the radio/ navigation screen doesn’t work. The screen does turn on but just shows black. I tried cleaning the disk but still no results. Any other tips before I decide to contact Alpine
Old Jun 11, 2018 | 09:40 PM
Hyperblu's Avatar
Short of checking the fuse to the navi unit, it will probably have to be refurb by alpine.
Old Jun 12, 2018 | 04:39 AM
john-germany's Avatar
Does the Navigation drive have a build in fuse?
Old Jun 12, 2018 | 11:07 PM
5th Gear
it does have a build in fuse, a 20 Amp fuse to be exact. I have checked the fuse but it seems nothing is wrong with it, in terms of the wires
Old Jun 12, 2018 | 11:34 PM
Can you describe, where the fuse is? Do you have a pic?
Old Jun 13, 2018 | 03:23 AM
5th Gear
The fuse diagram for 2006 TL
Old Jun 13, 2018 | 03:39 AM
Hi,
i thought about a fuse build in the drive. You describe the fuse under the steering wheel.
regards
Hans
Old Jun 13, 2018 | 02:31 PM
5th Gear
Yeah the fuses, are located on the driver side, under the steering wheel. I have checked only the Radio Fuse which uses a 20amp and it there’s nothing wrong with it. The screen on my navigation turns on but with only a backlight glow and sometimes a white line going through it or flickering. My stereos anti theft light turns on which could be a good sign.
Old Jul 16, 2018 | 05:06 PM
DagoRob1904's Avatar
8th Gear
Did you ever figure out what it was? I'm having the same problem
Old Jul 16, 2018 | 05:22 PM
5th Gear
Sadly I still haven’t figured it, I’m at the point of taking it to a shop to figure it out. I’ll keep you updated
Old Jul 19, 2018 | 12:03 PM
GhostTL09's Avatar
Well OP I gotta be honest. My 06TL did the exact same thing. I had nothing to lose so I took a hammer and banged on top of the unit about 5x. I then started the car and the navigation booted up and has been working without issue the last 2 weeks hahahahahaha.
Old Jul 24, 2018 | 03:14 AM
8th Gear
Bwahahahaha....Thats hilarious. I just might have to try that before I pull it out. Like you said ... Not much to lose at this point
bho15
Jan 6, 2020 02:48 PM
rudycat
Jun 23, 2018 10:45 AM
anoble1
Dec 29, 2014 06:21 AM
marky11707
Jul 16, 2009 11:04 AM
Recallz
1G RDX (2007-2012)
Jan 6, 2008 08:30 PM
