Big problems... need help (Sub + Noise Cancellation)
Old Jul 20, 2007 | 04:25 AM
  #41
2007 TLS's Avatar
also do i have to just diconnect the rear mic or can i get away by disconnecting the rear sub?
thanks again
Old Jul 20, 2007 | 05:45 AM
  #42
Converted's Avatar
THE PLANE TAKES OFF!!!!!
If you're putting an aftermarket sub and amp, it's best to just unplug the stock sub, but you can leave it in it's place if you'd like.
Also, unplugging the rear mic in the headliner will NOT affect your bluetooth... The bluetooth uses different mics.
Old Jul 20, 2007 | 08:45 AM
  #43
2007 TLS's Avatar
So if i understand this correctly....in order to get rid of the feed back noise all i have to do is unplug the existing factory sub and i DO NOT need to unplug the mic?? right?
Old Jul 25, 2007 | 08:40 AM
  #44
Converted's Avatar
Wrong.
It's best to unplug the factory sub, mostly just for sound quality, if you're using an aftermarket sub. That way it won't pop or distort.
You still need to unplug the mic from the rear headliner...
Old Jul 25, 2007 | 10:01 PM
  #45
2007 TLS's Avatar
ok so i unhooked the rear sub as well as the front and rear mic and i still have feedback noise?? is there another way to get rid of this?
Old Jul 26, 2007 | 10:15 AM
  #46
dirdyduzen's Avatar
8th Gear
Same problems but worse
I have had the same problem...my situation is worse. As I start to close my trunk the feedback gets worse and I have tried everything even disconnecting the ANC unit in the dashboard and nothing has solved the issue. I used to get feedback only when the doors were closed, but it doesnt matter.
Old Jul 26, 2007 | 08:49 PM
  #47
2007 TLS's Avatar
thats really odd and i'm not sure why you are having that problem. You might want to consider a noise filter.
Old Jul 26, 2007 | 09:21 PM
  #48
2007 TLS's Avatar
on the 07 tls...how do i stop the rattles....i have a dynamat trunk kit but it doesnt seem to help
Old Jul 27, 2007 | 08:27 AM
  #49
dirdyduzen's Avatar
8th Gear
So after you disconnected your mics you had no more problems?? I know you probably already know this but most rattle comes from the license plate...get two sponges from wal-mart or something and put it behind the plate and that should stop it.
Old Jul 28, 2007 | 05:02 PM
  #50
2007 TLS's Avatar
i put foam behind the lic plate and i turned the subs forward facing inside the car and i have a whole trunk kit worth of dynamat and nothing is working. It is really getting to a point where i get so pissed off now. The thing that bothers me is that i cant hear the bass coming outside my car as loud as i could hear it from my 02 tls and my 02 tls hardly rattled.
Old Jul 31, 2007 | 02:25 PM
  #51
cocokola's Avatar
well, that's the thing. You've done a great job with DYn etc that you've deadened the sound transfer ouside the car. You will need to just crank it up and start holding parts of the car until you find what is making the noise ; then see what you can do to shore it up more.
Old Aug 1, 2007 | 03:08 PM
  #52
dirdyduzen's Avatar
8th Gear
Rattle problem
I have found that most of the noise at least in the car is coming from the rear decklid where the speakers are housed. There is a plastic strip that vibrates against the window that is so loud that you can barely hear the bass in the car. I just put some paper wedges in between, but I recommend some weather stripping or something like that, even some folded carpet. That will help inside but if your trunk is still rattling add more dynomat. I dont think that there is anything else you can do....at least you are able to have bass in your car it wont even work in my 07 tls.
Old Oct 21, 2007 | 05:09 PM
  #53
BLACKURA_NY's Avatar
I have car ADD
this is why i f!@king LOVE acurazine.com
fix worked like a charm!!
Old Apr 25, 2008 | 12:14 AM
  #54
bigmoetl1's Avatar
wdp skyhawk
i have an 08 tl type s and i am getting the hum when the door is closed or when u cut the car on it goes away when the car is off or you open the passenger door i will try this fix and see what happens.
Old Apr 25, 2008 | 12:52 AM
  #55
bigmoetl1's Avatar
wdp skyhawk
Originally Posted by djilln
Issues with sub noise on '07 TL Type S
Instructions on unplugging the rear mic.
1. Use a small tip straight screw driver to pop out the plastic coverings for the lights.
Try prying each out from the center of the whole lighting fixture.
2. Unscrew two scews that hold the lighting fixture in place.
Use a wrench , it's easier.
3. Remove the fixture from its place and leave dangling.
4. Above the light fixture you will find a wire with a green clip.
5. Detach this clip.
If you pinch the clip from the top it slides out easily.
6. Reattach light fixture - Enjoy your new clean bass.
i got my beats working i love this site thanks.
Old Apr 25, 2008 | 12:55 AM
  #56
bigmoetl1's Avatar
wdp skyhawk
i ha ve an 08 had the same humming problem i followed the instructions unplugged the green wire and now clear bass
Old Apr 28, 2008 | 10:13 PM
  #57
henryr934's Avatar
Har/934
i love this web site i just bouth a TL type S 08 i had same problem so i toke everything but now i going to put it back
Old Aug 29, 2008 | 06:28 AM
  #58
ddtls's Avatar
Electrical Engineer
ANC with aftermarket SUB - Unplug Microphone(s)
Originally Posted by Converted
Ok guys... problem solved...
........You have to remove the plastic trip by the front dome light, and unplug the SMALL microphone. The two large slots are for the voice recognition system, which wont be affected. There's also a SECOND microphone behind the dome light in the rear of the car.
Once they're disconnected, problem solved. It's easy to reverse as well.......
Remember guys, this ONLY applies to the '07 Type-S
Within this thread are instructions to unplug the front mic only, the rear mic only, and the ANC module only. Anybody know which parts, or if all of this is necessary when adding an aftermarket Sub to an '07 TL-S?
Old Aug 29, 2008 | 06:31 AM
  #59
MWalsh9152's Avatar
all work and no play
Ive heard of some people only having to unplug the rear mic, and some havingt to unplug them both...its your choice as to which route you want to go to disable the system, if you go to the module then you wont have to unplug the mics, and vise versa
Old Aug 29, 2008 | 06:49 AM
  #60
ddtls's Avatar
Electrical Engineer
Thanks MWalsh9152,
That makes sense. So it appears that the rear mic is always a problem and the front mic is sometimes one?
Old Aug 29, 2008 | 03:49 PM
  #61
MWalsh9152's Avatar
Ive heard someone say that they have just had to remove the rear one....you mnight as well just do both of them at the same time and save the agrivation. It should only take a few minutes to disconnect them both
Old Aug 29, 2008 | 04:10 PM
  #62
cmt1's Avatar
The whole process should take < 45 minutes (with liberal stops for water breaks). Also, I have had mine disconnected for a month (without my new sub yes) and I can't tell the difference. Make me wonder if the ANC "REALLY" does anything substantial or if it's a marketing ploy.
Old Aug 29, 2008 | 08:31 PM
  #63
ddtls's Avatar
Electrical Engineer
Thanks guys, The Best Buy install kids disconnected the rear mic and left my sealed box sub connected to the rear speakers channel, claiming a connection to the rear sub channel generates intolerable feedback. They insisted it was not possible to get the system to work with the LOC on the subwoofer channel.
I will take out the front mic and change the LOC back to the sub channel where it belongs. I KNEW they were stumped and therefore blowing smoke to keep from admitting it when they told me the system would not work if my new sub amp got it's signal from the factory sub channel.
Old Aug 30, 2008 | 04:44 AM
  #64
CometVR4's Avatar
If you Type S guys are still having trouble I wouldn't mind swapping cars.
Old Jul 6, 2009 | 06:39 PM
  #65
gilla_monster's Avatar
Another happy acurazine member. Followed the steps from djillin and in 5 minutes, the buzzing was gone and my sub swap was complete. Awesome.
Old Feb 24, 2010 | 09:44 AM
  #66
spcslyusarmy's Avatar
Slythslyr
I also just installed a sub and amp and was having the same problem. I unplugged the rear Mic it still have a low humming sound. This car is new to me and I don't know how to take It all apart like my STI.. can someone tell me how to unplug either the ront mic or just the module under the center channel speaker. I looked at the module and Its tight In there. Should I unbolt it and then unplug? Then bolt I back In?
Old Feb 24, 2010 | 12:55 PM
  #67
Slythslyr
nevermind... i just figured instead of waiting for an answer i would just figure it out. Im pretty mechanically inclined so i knew i wouldnt have a problem but was just unsure on how to take apart some things. I hate breaking those little clips and such. I just pulled the center channel speaker and then unscrewed the little gray box. You dont have to take the nuts all the way off, i realized this later when i struggled to get them off and noticed that all i had to do is unscrew a little bit and slide it up and off. Once i unplugged the module all noise that i was having was gone.. Perfect. thanks Acurazine for helping me with my problem.. Now i just need to find a 3K HID kit for my fog lights...
Old May 24, 2010 | 02:50 PM
  #68
zrock87's Avatar
This thread is the best!!! Some problem with the HUMM, just put in an all new JL system cost me about 1200 and i was like WTF is that noise!!
also, the vibrating rear deck against the window is the annoying rattle, wedge something in there and youll be good! BOOM! LOVE ACURAZINE!
Old May 24, 2010 | 04:32 PM
  #69
zrock87's Avatar
This is the ROOT of all subwoofer EVIL!
Old May 25, 2010 | 09:24 AM
  #70
cmt1's Avatar
Originally Posted by ddtls
... The Best Buy install kids ....
That's the problem right there...
Old Jul 12, 2010 | 10:12 AM
  #71
JackSampson's Avatar
I think disabling this messes with the HFL. I can no longer hear messages on my phone through the speakers.
Old Jul 21, 2010 | 04:00 PM
  #72
1islandparadise's Avatar
I just installed 2 JL 10's and disconnected the rear mic, but my connector does not look like this. Mine was a small connector found on a microchip. Shortly after I disconnected it, a message on my nav screen about my TPMS comes on. Any else have similar problems? Im going to the connect the cable again into the little box up and see what happens.
Old Jul 21, 2010 | 06:56 PM
  #73
^^^Disregard got it working!~ Special thanks to Msala524...thanks!~
Old Jul 21, 2010 | 08:00 PM
  #74
Nick337's Avatar
if anyone is still having problems while unplugging both microphones, include the module underneath the center channel and no more feedback at all!!
Old Aug 7, 2010 | 03:30 PM
  #75
Joe Foe from Buffalo's Avatar
Ok I read all the posts and can't find it on my 05 non navi TL if anyone can pleazzze give me a clue
Old Aug 7, 2010 | 03:41 PM
  #76
John08TL-S's Avatar
Question
2 questions...
How do you get at the mic behind the front dome lights?
Also, where are you supposed to disconnect the ANC box behind this front center speaker?
Old Aug 7, 2010 | 04:04 PM
  #77
You only have to disconnect the rear microphone. Take out the rear dome lights and you will see a small box with a small connector. Unplug it and you're good to go!~
Old Aug 7, 2010 | 04:07 PM
  #78
I removed the rear dome light and the front one also and can not find it in my 05.
Old Aug 7, 2010 | 05:32 PM
  #79
John08TL-S's Avatar
Update:
Okay, so now the rear mic is disconnected, ANC module is completely removed, and still getting the humming coming from the subwoofer after I start the car. Doesn't matter whether or not the doors are open or closed, and the any use of the windows/AC seems to make the humming noise get louder.. Any ideas anyone?
Old Aug 7, 2010 | 06:07 PM
  #80
John08TL-S's Avatar
Originally Posted by John08TL-S
Update:
Also wanted to add that when I turn my key once (accessory only position) I hear 3-4 loud subwoofer thumps but do not hear the subwoofer humming. Once I start the vehicle, the humming begins. If I put the car into drive, the humming doubles..
