Big problem...looking for help...
Old Sep 25, 2004 | 07:46 PM
mgothers's Avatar
Ok, I did a quick search and did not find anything...
I'm going out to best buy and play some pool and everything is cool.
Listening to XM radio as I pull in to the Best Buy parking lot.
Go in, get what I wanted, come out and turn on car...
As i'm driving through the parking lot i realize no sound...so I turn it up...nothing...so i go to turn off the radio...power button doesn't do anything. I try to switch to CD, disk/tape button doesn't do anything. I try to switch to radio...fm/am button doesn't do anything. I spin the chanel button...it switches XM (on display) but no sound. I spin the volume...the display shows a change in volume...but no sound.
I use the steering wheel controlls to switch to CD...it works but no sound. I try to use the buttons to switch disks...no response. If i use the touch screen the disks change (as do the XM radio if i'm on that). But the physical buttons do nothing.
I hit the voice command button...i don't hear the voice, but i say disk 5. It switches to disk 5 but nothing. I say XM it switchs to XM but nothing.I say AC off the AC turns off, but again no voice.
I say stereo off and it switches off. I can't use the big power button to turn it on but i can turn it on with voice commands.
Anyone hear of this???
I'm about to disconnect the battery to rest the system but i wanted to see you're all responses first.
Matt
Old Sep 26, 2004 | 11:46 AM
csunracer's Avatar
I like you, do u like me?
I've never heard of this happening, but perhaps it's something as simple as a blown fuse?
Old Sep 26, 2004 | 12:00 PM
cM3go's Avatar
Disconnect the battery
this specifically didn't happen to me, but my HFL locked and no sound worked... once i disconnected the battery for a few seconds everything worked fine, just a glitch
Old Sep 26, 2004 | 05:52 PM
mgothers's Avatar
I tried to disconnect the battery...no go, same symptoms.
I checked the fuse (#5). It's fine.
I guess I'll have to set up an appt with the dealer.
Man, you never know how much you miss it till you drive by yourself w/o it!!
M
Old Sep 26, 2004 | 10:11 PM
sw1tchn1nja's Avatar
Sounds like the antitheft system was activated, find the code in your glovebox probably and type it in, if it says ErrE on your upper console disconnect your battery for 1 minute, then type it in. As you type in the code it should start to spell CODE on your upper dash
Acura604
2G RDX Photograph Gallery
17
Feb 8, 2021 03:32 PM
Jul 16, 2017 07:33 AM
Jinkazetsukai
Nov 21, 2015 05:28 PM
Froid
Sep 27, 2015 06:16 PM
