Basslink Install question
Old Jul 6, 2008 | 09:50 PM
saxballuiuc's Avatar
I have searched high and low through the forums for an answer to this question, so I figure it is worth throwing out there.
I have a basslink I am installing. I have run both the power and ground wires to the unit. There seems to be a few different ideas about getting signal to the unit. I tapped the stock sub wires. My question is to use the line output converter (LOC) of the high level inputs that are available on the basslink. I have a two channel LOC and the sub signal is only one channel. I tried to use just one channel of the LOC and it didnt work. I also tried tapping the stock sub wires twice for the high level input, but that also didnt work. I was trying to avoid running another wire from the front for the remote wire, but I will if I have too.
Just want confirmation from someone who has had it work.
Old Jul 6, 2008 | 10:06 PM
csmeance's Avatar
You just stated your answer, the LOC won't work, and you can use the high inputs.
Old Jul 11, 2008 | 10:24 AM
4DGSR's Avatar
You will need to run the remote wire for the sub to turn on.
hues10
1G RDX (2007-2012)
Sep 7, 2016 03:47 PM
Skirmich
Sep 15, 2015 06:41 PM
datadr
Sep 12, 2015 09:12 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
