Motoral Razr2 v9m
Mine paired up on the second try on my 08. Unfortunately, phonebook import and data connection do not work with the phone; otherwise everything is great.
I followed the directions on the HFL website -
1. Power on the phone and ensure Bluetooth® is ON. Please refer to your phone's user guide for steps to turn on Bluetooth.
2. Press and release the TALK button on the steering wheel and wait for the "beep" before you speak. Repeat this step before all spoken commands.
3. Say "Phone Setup"
4. Say "Pair"
5. Say any 4 digit PIN code for pairing. Remember it as you will need to enter it into your phone later. Some phones have a pre-set pairing code of "0000". Please consult your phone's user manual to see if your phone has this requirement. HandsFreeLink will now instruct you to begin the pairing process in the phone.
6. Enter the main menu
7. Scroll over to Settings & Tools
8. Press 3 for Bluetooth
9. Turn BT power on
10. Press OK to begin a new search for pairable devices
11. Press OK at the pop up message
12. Once search is completed, select device from the list to be paired with and press OK
13. Enter the Passkey & press OK
14. Name the device when asked
15. Assign a priority if requested
4. Say "Pair"
9. Turn BT power on
Thanks. I got it to work with some help from Acura. On the Razr2 I had to start by choosing "Add a device" as opposed to just putting it in "discovery mode" as the phone's manual had instructed. All's well.
Jamus22
Jun 11, 2023 10:08 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
Sep 25, 2015 06:14 PM
