Audio noise
Old Dec 7, 2007 | 01:20 PM
77donovan77's Avatar
....just dancing in
Audio noise
After doing the DVD mod... (Dom's unit, Dice unit, Accelevision) I've notice I get electrical audio noise when the engine is running. Crystal clear audio when engine is not running......any remedy to this annoying noise problem would be greatly appreciated.
Old Dec 7, 2007 | 01:52 PM
berzerker's Avatar
Unshunned
I don't know what a dvd mod is, but I would guess you had a ground wire come loose from the head unit or need to put one on (or a better / cleaner contacting one) the device(s) you installed during this mod. you may have a ground loop.
http://www.installdr.com/TechDocs/999502.pdf
Old Dec 7, 2007 | 02:07 PM
....just dancing in
....DVD mod? I thought I was clear in my statement. Able to view dvd's, etc. thru the Navi. Thank you for your suggestion. I will go back and look into where I grounded all the units.
Old Dec 7, 2007 | 03:22 PM
berzerker's Avatar
Unshunned
You may have been clear before, but only to those people that are familiar with what you had listed or knew you had a nav. I just haven't heard of those items listed, as I don't have a nav TL, so I just assumed they were hardware bits.
Anyway, good luck finding the source of the noise, I do know what a pain that can be
Old Dec 7, 2007 | 03:32 PM
berzerker's Avatar
Unshunned
I forgot to add:
please post back here if you get it solved so others can benefit.
Old Dec 7, 2007 | 07:57 PM
....just dancing in
I forgot to add:
Hey berzerker......it was the DVD unit that was improbably grounded. I relocated that ground wire and now no annoying electrical audio noise......once again Thanks
Old Dec 7, 2007 | 10:04 PM
berzerker's Avatar
Unshunned
nicely done. Ain't nothing worse than doing all that work and you're all excited about hearing/seeing your project finished only to have something so small bring it all back down again.
hope it wasn't too much work to get it fixed. Now go enjoy it!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
