Audio noise
Audio noise
After doing the DVD mod... (Dom's unit, Dice unit, Accelevision) I've notice I get electrical audio noise when the engine is running.
Crystal clear audio when engine is not running......any remedy to this annoying noise problem would be greatly appreciated.
I don't know what a dvd mod is, but I would guess you had a ground wire come loose from the head unit or need to put one on (or a better / cleaner contacting one) the device(s) you installed during this mod. you may have a ground loop.
http://www.installdr.com/TechDocs/999502.pdf
Originally Posted by 77donovan77
....DVD mod? I thought I was clear in my statement. Able to view dvd's, etc. thru the Navi. Thank you for your suggestion. I will go back and look into where I grounded all the units.
I just haven't heard of those items listed, as I don't have a nav TL, so I just assumed they were hardware bits. Anyway, good luck finding the source of the noise, I do know what a pain that can be
I forgot to add:
please post back here if you get it solved so others can benefit.
nicely done. Ain't nothing worse than doing all that work and you're all excited about hearing/seeing your project finished only to have something so small bring it all back down again.
hope it wasn't too much work to get it fixed. Now go enjoy it!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
