Anyway to clear error codes stored in Nav?
Old Jun 14, 2011 | 02:11 PM
JTS97Z28's Avatar
I did a search and didnt come up with much. Basically, over the weeks I have been diagnosing an issue with my 08 Type S 6mt in which several codes were triggered. I am able to clear the normal check engine light either by disconnecting the battery, or using my auto tap software, but is it possible to get rid of the stored codes in the nav without going to the dealership? Its weird there is a button that says delete codes, but it is never highlighted so you can press it. I guess its not a big deal that they are stored in there, but if im able I would prefer they are removed.
Thanks,
James
Old Jun 14, 2011 | 06:55 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Try this and if there is a problem the message will come back, otherwise this worked for me and will you as well.
You'll need to evoke the diagnostic screen first, get in your car, turn the nav on, and hold down the "GUIDE", "MENU", and "CANCEL" buttons for about 5 seconds. The factory calibration screen will come up.
Then click on XM module, and you'll see the option to erase those messages. Believe it or not the diagnostic messages are stored in XM module.. dumb.
P.S. word of advice, be careful
Old Jun 14, 2011 | 07:06 PM
JTS97Z28's Avatar
Awesome, I will go give it a shot. I have actually gone into this diagnostic menu on other TL's I have owned with no issues. Thanks much.
I will go try it.
James
Old Jun 14, 2011 | 07:07 PM
paperboy42190's Avatar
I will go try it.
James
lemme know how it works out for you. any benefit to erasing all these messages?
Old Jun 14, 2011 | 07:16 PM
JTS97Z28's Avatar
Thanks very much for the help it worked perfectly!! The only reason I wanted to is because a couple weeks ago I was doing some diagnosing which required disconnecting a couple sensors which in turn obviously triggered some codes. I was able to turn off the codes and reset the CEL, however the messages in the nav system stayed there. No real reason but I just didnt want them there anymore I like to keep everything clean...sort of like cleaning your PC and deleting your history if that analogy makes any sense. lol
Thanks again.
James
Old Jun 14, 2011 | 07:17 PM
NBP04TL4ME's Avatar
If you have diagnosed and/or fixed the issue related to the messages then there is really no need to retain the messages.
I had an issue with a TPMS error because I had put rims and tires on my car that didn't have TPMS. I knew I was going to have a problem - just didn't have the extra TPMS units for my second set of rims. When I had them installed the TPMS worked fine, but still had the error messages.........
Old Jun 14, 2011 | 07:18 PM
NBP04TL4ME's Avatar
Thanks again.
James
You're welcome and glad it worked out.
Old Jun 14, 2011 | 10:41 PM
Titanium2k2's Avatar
This is GREAT info! I have a few old TPMS messages stored in mine that pop up from time to time. I'm going to give this a try...
Old Jun 14, 2011 | 11:37 PM
aIRpeACE's Avatar
it shouldn't be a big problem
Old Mar 21, 2012 | 09:12 AM
SharksBreath's Avatar
BANNED
just wanted to bump this bc it's good info.
had to clear a bunch of stored messages over the weekend, works like a charm.
Old Mar 21, 2012 | 02:44 PM
NBP04TL4ME's Avatar
Glad it worked out. This is what makes this site so good
Old Apr 6, 2012 | 08:22 PM
YMCMB TYPE-S's Avatar
Man that's a great tip… my cars been fine since I got it but I did notice those messages saved and it was aggravating just knowing that they were there and that nothing was wrong with my car…… tried it and was successful
Old Apr 7, 2012 | 12:05 PM
NBP04TL4ME's Avatar
Just as an FYI - You can evoke the diagnotics menu the same way on the MDX as well - we have an MDX as well. I'm not sure about the whole Acura lineup, but would assume so.
Old May 17, 2012 | 08:55 AM
peter57's Avatar
8th Gear
Interesting. Thanks. Does anyone have any experience with this working on a 2005 RL? I cleared the error on the dashboard using an OBDii scanner but the error message persists on the nav screen
Old May 17, 2012 | 06:50 PM
peter57's Avatar
8th Gear
Rushed home to try the fix on my 2005 RL. It worked exactly as described. Well done and Thanks!
Old May 17, 2012 | 08:14 PM
NBP04TL4ME's Avatar
Good Deal - glad it worked
Old May 22, 2013 | 06:25 PM
dudester7's Avatar
2012 acura tsx navi
I tried this on my 2012 tsx with the tech package. It also worked. Thanks for the tip!
Old May 22, 2013 | 06:47 PM
Morrissey25's Avatar
contemplating future mods
Great info... This thread should be sticky'd!!!
I am going to my car to try it out right now!!!
Old May 22, 2013 | 07:04 PM
So I tried this and got scared that I was going to mess something up...
I have an 08 TL-S and I want to make sure that I hit the right things. Here is what I have so far:
I hit held down the 3 buttons and this came up:
Then I hit the XM ECU button:
Thought that I would reset the data:
Then this came up and I got scared:
I don't see a "delete" button... MOst of the codes that I did see on another screen were from changing my steering wheel and pulling out the airbag, when I installed the RV-6 Exhaust, HFPC's, and TPMS related things.
Please advise
Old May 24, 2013 | 07:04 PM
NBP04TL4ME's Avatar
It has been awhile since I have had any error messages to clear, but just looked in my TL. If I remember correctly you want to choose option #3 Diagnostics Info and not option #1, which I believe you have selected in your pix.
Perhaps others who have cleared codes more recently can confirm / correct.
Old May 25, 2013 | 12:40 PM
Thanks for the response. I hit option 3 and I saw the three codes that I had. When I tapped on each individual code I was sent to a screen where I could erase them. Thank you.
Then, out of curiosity, I hit the DTC logdata (option 2) and this screen came up:
When I hit one of the airbag system logs I got to this screen:
Is there any way to clear these logs? What do all the numbers mean? There didn't seem to be any real correlation between the "trip" numbers (time and mileage/km) and the various codes that were shown.
If and when I sell my TL, I don't want the buyer to think that my car has issues from installing the HFPC's and modifying my steering wheel trim
Old May 25, 2013 | 01:21 PM
NBP04TL4ME's Avatar
Not sure what those messages mean or if they are clearable or are part of the permanent datalog. You would probably need to talk with an Acura / Honda tech for that.
In terms of a buyer finding or seeing these, while possible, I would think very improbable.
Old Jul 17, 2013 | 01:02 AM
sauceja's Avatar
Desert Life Sucks!!
Thanks, I had a fuel cap code and another related fuel issue code that has been fixed.
I still had these codes. I followed this thread and option 3 and was able to clear the codes I had stored.
Now I can monitor the system for any future issues. Thanks for the tips from many years ago.
Old Jul 17, 2013 | 06:29 AM
NBP04TL4ME's Avatar
You are welcome and sounds good.
Old Jul 19, 2013 | 05:30 AM
SixtwoPinoy's Avatar
I just got my TL and I noticed I had some codes in the Navi system. So does that mean those codes has been fixed?
Old Jul 19, 2013 | 08:53 AM
JTS97Z28's Avatar
^^^ well it seems that some codes automatically get stored and come right back no matter how many times you delete them. I figured its normal because pretty much all of the TLs I have owned did it. However if you actually did have a check engine light on using this delete method will remove it from the system completely, unless ofcourse the problem was to come back.
Old Jul 19, 2013 | 10:38 AM
sauceja's Avatar
Desert Life Sucks!!
Yea, its still good to clear codes. If you have an issue they will come back.
Either write them down first or look them up to see what kind of problem it was. That way you can build a history with your car first.
Old Jul 19, 2013 | 03:48 PM
NBP04TL4ME's Avatar
+1^ This. If the problems that caused the codes to be captured are still there - when you clear them the will come back. If you clear them and they don't come back, I believe you should be all set.
Old Sep 9, 2013 | 02:15 PM
robpp's Avatar
Graphite Ghost
TSX Wagon. Screens a bit different but went Self Diagnosis, then chose XM (hip) then #3 diagnostics. Then u chose each one and delete them. Thanks.
Old Sep 9, 2013 | 06:32 PM
NBP04TL4ME's Avatar
You're welcome!
Old Mar 17, 2014 | 10:50 PM
KrisKasprzak's Avatar
Anyone know how to do this with a 2010? I've tried these steps and it doesnt' seem to work with the 4th gen NAV systems.
Old Mar 18, 2014 | 01:20 PM
NBP04TL4ME's Avatar
Probably similar but slightly different. I don't have a 4th gen to play with so I won't be able to help. You might want to post in 4th gen and reference this thread.
Old Jul 13, 2014 | 09:52 PM
aameghoo's Avatar
No option for a 2005 TL Nav version 3.40C? This is the screen that comes up when I do "GUIDE", "MENU", and "CANCEL" buttons for about 5 seconds
Old Jul 14, 2014 | 08:42 AM
The Big Dog!'s Avatar
Screen
I get the screen without the XM option........
Old Jul 21, 2014 | 06:46 PM
nokkieny's Avatar
my 2005 is the same
Old Jul 21, 2014 | 06:51 PM
NBP04TL4ME's Avatar
Reasonably sure it worked on my 04, but no longer have it to test. Definitely works on my 08 TLS. Not that I think it would matter but do you have an active XM subscription?
Old Jul 22, 2014 | 01:07 AM
Jriddle8's Avatar
I have a 07 Tls and i dont have that XM option as well.
Old Sep 25, 2014 | 11:46 AM
NBP04TL4ME's Avatar
Maybe it's different in Canada??
Old Feb 6, 2015 | 05:53 PM
JTYankFan's Avatar
Just had to do this today.. NBP04TL4ME, of course I had to say Thanks as well!
Old Feb 6, 2015 | 06:20 PM
NBP04TL4ME's Avatar
