anyone have a radar detector (valentine one) hardwired in their TL?
06 TL Owner since 10/31/0
i was debating on hardwiring the valentine one into the TL. i was wondering if anyone has pulled this off and had any pictures of the final product.
Originally Posted by CleanCL
i have one hardwired. the laser shifters are positioned on my front / rear bumpers, the radar detector is inside the front bumper. i have a small control screen that is mounted on my steering wheel column.
Wiring a radar detector is not a big deal. I've wired my V1 to my last 6 or 7 cars with remote display and it's like a 20min job.
I have my detector mounted at the top of the windshield to the passenger side of the mirror with my remote display mounted around about my VSA button. I drew power from the fuse box and ran the wire up my a-pillar and tucked it under the trim, and then across the front of the headliner and tucked the wire up under there as well.
It's easy as pie, you can do it. It's the only way to go. Remote and hardwire.
OMGWTF4THGENTL
My V1 is hardwired, ran the wire up the Apiilar and it's mounted in the top left corner of the windshield. Seems like a good spot, I've been stopped twice with it mounted there (HOV violation and front plate... our law enforcement officers are truly focused on the right kind of criminal around here... in VA it's illegal to use a radar, but neither cop noticed it there.
There's a thread in 3G garage discussing how to hardwire it in properly.
My remote display is mounted here:
Kinda neat that way. The door closes and it's outta sight.
Keep Right Except to Pass
To the original poster, search the board; several people over the years have posted info on this, including "how-to" guides with pictures.
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
Seriously, I've been using a portable Cobra unit mounted low, 'cause I thought it would be better for laser and to save a few bucks over a hard-wired unit. But I don't like to keep unplugging it (so nobody will steal the unit), so a hard-wired unit is probably the way to go. That little door may be elegant, but when you have to open it every day, it's annoying.
Around Jersey it seems like the the troopers can have their radar guns aimed at you and the detector stays silent.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
OMGWTF4THGENTL
Final- this is not the actual detector, the is the Valentine 1 remote display. The actual detector is attached to the top left corner of the windshield. Best place for it... High mounted, not visable from outside the vehicle.
Finally... a use for that too-small compartment next to the cigarette-lighter plug!
Maybe they're all using instant-on or laser?
2012 Cadillac CTS-V Coupe
Originally Posted by HiTEC
You're better off having your detector higher on the windshield than lower for laser. Not to knock you, but your probably having problem because you're using a Cobra. Do yourself a favor and dump that Cobra and get yourself a v1, 8500, or Bel STi.
Now for radar, it is the opposite. You want the detector mounted high, but detectors like the Bel/8500 and V1 have such great range (sometimes 2 miles away) that you're really not sacrificing much by putting it low.
I tend to agree, with the other V1 user, and the web site. Aside from the LED taillights on Chevy SUVs, and the cruise control sensor on the Infinity I get the best results from the top, I mount mine right above the rearview and do not use the remote display.
http://valentine1.com/laserhowto/
ITSJESTER
17
12-06-2018 02:29 AM
chrisr
12-04-2015 02:17 AM
sockr1
10-01-2015 01:31 AM
