anybody use these to protect the nav screen
I have heard of many folks using the screen protector from Strong Engineering.
http://strongengineering.com/miva?/M...uto+Navigation
Originally Posted by Jerky
YOu dont have to use the touch screen to access stuff
Use the JOYSTICK!!!!!!!!!!!!!!!
I've used they joystick, but often when I push it in (especially while driving) the stick moves before I press. Beginning a maddening dance of pressing cancel and trying to position that little devil, orange square to where I want it. And then beginning the dance again.
dashotgun,
Did you try the nu shield protectors after all? If so, would you recommend them?
For now, I'll try the maintenance route with the highly recommended (from various threads) soft microfiber cloth.
thx...
ps. I am not a fan of the joystick.
thx...
Keep Right Except to Pass
On the rare occasion when I touch the screen, I don't use my fingertip because I hate the spots it leaves. I'll either grab a tissue from the cupholder and use that, or I might use my sleeve, or sometimes I just bend my finger down and use the joint to touch the screen. I seldom touch the screen, although I agree that if you hit a bump or something the joystick can be frustrating.
I'm Baaack!
Use the back off your fingernail (not the tip) no oils and it will not scratch the touchpad ... You can use this method on a PDA as well then you don't have to use the stylus.
Its all about Hockey !!!
I was actually thinking of getting a screen protector like that... I mainly use the touch screen (as it is much easier then joystick), and it does leave some marks on the screen. Of course I clean it, but I figure getting a screen protector will only help..
thanx for the link
thanx for the link
I have the screen protector designed for the 04 TL. I really like it since I dont have to worry about getting the touch screen dirty or messed up. It does really help...I havent even cleaned the screen protector since it doesnt need any cleaning. So I highly recommend it!
I agree I bought from nuscreen customer service was vg one screen was shipped with a sl kink in it they shipped me a new one no problems. it fits perfectly and as narmeen mentioned does not need to be cleaned. they provide 2 screen protectors for the price. Highly recomended if your fussy about your car.
I tried one from Strong engineering and was not impressed. The fit was not the best.
I removed it and am thinking of trying one from NuShield. Hopefully the fit is better
i use J&J earbuds to tap on the nav screen.
Uhm... never heard of a screen protector designed specifically for the 04/05 TL... got any links for it?
I use the one from Strong's Engieering.
Even if you are really good about not scratching the nav screen, somebody in your car that can't get their hands off the XM of the nav eventually will. It also makes cleaning a breeze.
I also have the Strong Engineering protector and have not been impressed with it. Fit is lousy, it doesn't stick well and it clouds the display too much. I'm going to try out the nuscreen one as well to see if it works any better. Thanks for the tips.
Mark
Mark
Originally Posted by pilozm
I just want to make sure. Does the nushield product adhere to the NAVI? That is, is there a glue that allows the screen protective stick to the screen?
Registered TL User
I contacted nu shield shortly after I picked up my TL back in October '04 because they didnt have a shield protector for the 2004/2005 TL. So, they offered to let me be the tester for the TL screen protector. I provided the measurements for them and they sent me out a few shields to test.
I highly recommend these. The folks there are great. The product works great, there is no adhesive and you cant even see them. All you see over time are the tons of fingerprint smears at which point you simply throw it out and replace with a fresh one. Try that with your actual nav screen.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
