Any side effect for disconnecting battery??
Forgot the 4 digit password for HFL, and I tried pulling out fuse 6 to reset the HFL, but it didn't work. I want to try disconnect the battery. I'm wondering is there any side effect for disconnect the battery? I think I got some info about disconnecting battery will cause some malfunction. Is that true?? Thanks in advance.
you will loose your radio presets, memory settings and a few other things. As well after reconnecting make sure the car idles for 15 minutes with all the accessory components off (radio, A/C, heater, etc)
Thanks a lot. I disconnected the battery and waited for about 20 hrs, then reconnect the battery. But the HFL is still locked and the seats memory is still there. The only things reset are the radio and the clock. Any suggestion for that??
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
scionxb3003
Sep 14, 2015 01:52 AM
2003, 2004, acura, affect, batters, battery, bmw, car, cl, computer, disconnect, disconnecting, disconnection, mdx, tl
i'm SURE he meant that as a joke...lol
