Another Nexus 7 tablet install
Old Sep 12, 2014 | 04:42 AM
champaned_out's Avatar
Finally got around to doing this.. took me alot longer than i thought probably around 7 hours total from start to finish.. mainly because it was my first time taking apart the center console in this car, i didnt want to break or scuff anything up
i know almost nothing of car audio/wiring/electrical things but because i was able to gather all the info from all the other members on this board and over on xda the install itself wasnt all that bad... i would say it was around 6/10 difficulty for a first timer like myself
so i have a 05 TL w/navi and the main problem i ran into was space... since i still needed to have the actual navi unit still in the car so i can have use of all my fan/ac buttons i had remove the metal housing of the navi unit and then flip the screen and secured it... time consuming in the end but everything ended up fitting just right there was no cutting into the dash or center console at all... if i ever have to revert back to stock i have the option to at anytime
my setup went something like this...
nexus 7 --> OTG-Y Cable --> 6ft micro usb 28AWG to 2.1A car charger in arm rest
OTG-Y Cable --> 6ft usb extension 28AWG to arm rest ---> 4 Port USB Hub --> Fiio E7 USB DAC (upper arm rest) --> Grom Audio Aux Adapter --> OEM 6 Disc CD Changer
im grandfathered with verizon on the 4G unlimited so i wifi hotspot to supply the tablet with internet
with this setup i have a fully functional OEM AM/FM Radio, CD, Tape, and HFL... i press CD twice and it changes to CD-C which then gives me audio from my tablet/dac
and im using the last rom update from Timur's USB Rom 4.2.2
Old Sep 12, 2014 | 11:27 AM
tjl_48's Avatar
What are you using on the main screen for the theme? I have one installed and am just using the normal android screen with a couple shortcuts. It works but isn't the prettiest. I like the look of yours.
Old Sep 12, 2014 | 02:02 PM
the home screen layout is actually just a wallpaper i put together.. i used desktop visualizer to make transparent shortcuts and placed them over the wallpaper... then i used UCCW to make the clock date and temp on the left side of the screen
Old Sep 17, 2014 | 09:27 PM
07-SilverTL-S's Avatar
looks good man ive been thinking about doing this myself
Old Sep 17, 2014 | 09:40 PM
Steven Bell's Avatar
A few more pictures would be nice......
Old Sep 17, 2014 | 09:49 PM
triax37's Avatar
....as well as a review after using it for last week or so. Hope you're enjoying it!
Old Sep 11, 2016 | 11:39 AM
sockr1's Avatar
thread from the dead! how is your tablet setup holding up? any tips or advice you'd do differently after having it for 2 years? looking to add this to my setup! i'm looking at triax37's thread as my main source but curious to see your thoughts on it since you started pretty fresh and new to changing up wiring/electrical stuff
iesu3423
Oct 6, 2015 06:54 PM
Sep 21, 2015 08:44 AM
TxRzrBk
Sep 17, 2015 01:07 PM
gnuts
Sep 11, 2015 10:07 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
