Another bypass question
Old Jan 16, 2018 | 03:06 PM
joe diego's Avatar
my Car: 2004 non navy Acura TL
I’m installing a simple double din and I purchased the $5 wire harness from eBay.
Amp failed so I removed it. As far as bypassing, all I have to do is extended the speaker wires from the harness to the wires that were coming “out” from the factory amp?
Ive searches but I was a lil confused with Navi and non Navi systems. Thanks in advance
Old Jan 16, 2018 | 04:29 PM
b15's Avatar
b15
That is correct. You can either extend from the HU to the output side of the factory amp, or connect the HU to the vehicle harness normally and then do the bypass at the amp location.
Old Jan 20, 2018 | 05:06 PM
joe diego's Avatar
Thanks for responding. This helps a lot.
Old Mar 6, 2018 | 08:15 PM
joe diego's Avatar
Just got done installing a pioneer double din. Rear speakers working, tweeters tweeting, front right I can barely hear and front left I can’t hear at all. Are my front speakers blown?
I tripled Checked the wiring. I used sauter and heat shrink for all wiring.
Old Mar 8, 2018 | 10:21 PM
joe diego's Avatar
*Bump
If the tweeters are working then why are door speakers not working? According to the wiring diagram the tweeters use the same wires as the front door speakers.
Old Mar 10, 2018 | 01:23 AM
stevemk07's Avatar
Originally Posted by joe diego
*Bump
Bad soldering job/poor connection is my guess
JTS97Z28
Sep 7, 2011 05:15 PM
ash3ktl
Jun 13, 2003 05:41 PM
r3mix3r
Jun 4, 2003 04:28 PM
Dom418
Feb 6, 2002 12:48 AM
id
Aug 18, 2001 04:32 AM
