Amp wiring question
Old Sep 18, 2012 | 09:54 PM
EvilJoker's Avatar
All Around Klown
Amp wiring question
OK... need opinions... I cant handle not having my thump anymore... I want to get my Infinity Basslink Sub wired up in the TL and want to know:
First: where you guys run the feed wire for the amp power... up the middle of the car (under the console and such) or down the door sills/railings...
Second: can I tap into the on/off signal wire for the factory amp to turn my Infinity sub on and off?
Third: My sub has audio jack inputs as well as direct feed input. can I disconnect the factory sub and rout those directly into the Infinity sub feed. I've never ran pre-powered wires into an amp before.
Old Sep 18, 2012 | 11:52 PM
pohljm's Avatar
I think on the basslink if you run high power inputs you dont need the separate trigger signal. run power down drivers side sill. Its closest to firewall penetration and battery
Old Sep 19, 2012 | 03:50 PM
jda123's Avatar
Dogmatic Dinosaur
The stock HU is on all the time. It is necessary for HFL and Navi (if applicable). Most of us use and accessory fuse (like #32) to power the audio equipment.
I ran my wire down the drivers side. Around the foot rest can be tricky if your wire is thick - I have to modify the trim to fit over 0 gauge.
You can use the signal from the sub in the trunk. The gold/black wire is the positive.
Old Sep 20, 2012 | 10:34 AM
EvilJoker's Avatar
All Around Klown
thanks... you guys are awesome!
I've had this sub for literally about 10 years and it still looks new and thumps with no problems...
BoricuaTL
Apr 8, 2016 01:08 PM
Type S Zero
Feb 17, 2016 02:37 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
datadr
Sep 12, 2015 09:12 PM
alan_rich
Sep 7, 2015 11:08 PM
