Amp install!
Old Oct 8, 2007 | 07:28 PM
97whtse's Avatar
Amp install!
Hey guys quick question, im going to finish installing my sub tomorrow and i would like to know the best location to bolt the ground wire and what to hook up the remote wire to. All the plastics and back seat are still off the car.
Old Oct 9, 2007 | 09:55 AM
rodneyc77's Avatar
Retired!!! ON TOP!!!
remember to grind away all the paint when you are installing the ground wire. Just find a location that's less than 2 feet from your amp and you should be okey... also make sure you don't drill into your gas tank... lol
Remote wire... just tape into the white wire of the cigarette lighter... in the center console...
Old Oct 9, 2007 | 11:14 AM
7Davie7's Avatar
For the remote turn on wire look at this tread...use an "add-a-circuit" to make it super easy and clean with fuse #32 under drivers side...VERY EASY
https://acurazine.com/forums/showthread.php?t=136870
Old Oct 9, 2007 | 11:19 AM
7Davie7's Avatar
for the groud, use this bolt shown below (i grabbed this from Deathtotoasters amp install - GREAT DIY) ( https://acurazine.com/forums/audio-video-electronics-navigation-22/questions-adding-sub-amp-120614/)
go to wear he has a pic of the stock ground and use that...i used it for my Basslink...works great and is VERY easy to use...size 10mm socket...
AndrewS
19
Mar 14, 2024 06:59 PM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
TxRzrBk
Sep 17, 2015 01:07 PM
Pegon95
Sep 15, 2015 01:54 PM
