Aftermarket woofer possible for 07 TLS?
6th Gear
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Recently I bought a 2007 TLS, and I was satisfied with most of the car except the factory audio system. So I figured that I would just replace the factory with JL audio. WRONG!!! Acura told me (after I spent over $4000 on a new system) that it would not be possible due to the active noise cancellation feature on the TLS. Does anybody have a solution to this? Or am I really just S.O.L.......
Help! I don't want to get rid of my TLS but its starting to look like an option
6th Gear
![Smile](https://acurazine.com/forums/images/icons/icon7.gif)
[The noise cancelling uses the factory sub woofer and other speakers to accomplish the actual "cancelling" so the cancelling effect is multiplied like 10x when using an aftermarket sub woofer...
I called JL audio and spoke with their tech support. He said I had to disable it, and instructed me how to do it.
You have to remove the plastic trip by the front dome light, and unplug the SMALL microphone. The two large slots are for the voice recognition system, which wont be affected. There's also a SECOND microphone behind the dome light in the rear of the car.
Once they're disconnected, problem solved. It's easy to reverse as well.]
Thanks for the reply, this has been a very frustrating for me
TL Driver and Loving It!
I believe the standard 07 TL also has some Automatic Noise Cancellation which can be adjusted with the control panel on the Navi. It can be minimized which might help, but, sounds like the microphone disconnect did the trick.
'07 NBP TL
6th Gear
Just an update....To put an aftermarket system in the Type-S you have to disconnect the front microphone and a rear microphone then disconnect a grey box I forgot what it is called......but it is possible! Don't let Acura tell you its not!
kb1rl
09-30-2015 10:17 AM
xsilverhawkx
09-28-2015 06:51 PM
