Adding After Market amplifiers
Well guys i kinda new and i only been on here couple of times i would like to say im a proud owner of a 2005 acura tl. i have recently done couple of mods to my car such as the isimple for the XM and also installed tweaters and front door speakers. now i am moving on to rear deck speakers. i installed the polk audio db651s their shallow so they fit right in =D. well my question is how do i exactly add a aftermarket amplifier using
PAC AOEM-HON20 i would only like to amplify the door speakers and the rear deck speakers if its easier. if its the same amount of work i might as well go all the way. anyone have any ideas. thanks for any help. also if you have anyquestion on how i installed my speakers let me know!
1. What speakers did you install?? Brand/Model of each one...
2. If you wanted to add an amp, you can add a 4 channel amp to power the fronts/rears on 4 channels.
3. What's your budget for an amp?
4. Will you be adding a sub at any time?
You'll need a way to convert our balanced signal to unbalanced also (you'll get noise through tweeters if you dont). Once we know which speakers you used, we can recommend what amp to use based on power requirements.
4drviper
Apr 23, 2025 07:13 PM
