Add-A-Circuit Tip
Old Mar 22, 2005 | 01:32 PM
AdamNJ's Avatar
Make MyTL Great Again
Lightbulb Add-A-Circuit Tip
Don't be like me. Don't waste an hour wondering why you aren't getting any power on your new wire.
When you use add-a-circuit, make sure you have a fuse in both spots of the unit, otherwise you will get no power on the wire for the new device.
Yesterday I was trying to install my Escort Passport 8500 x50. I installed the add-a-circuit device into #29 on the fuse box (the IGN OP1 - free for owner use). I only put a fuse in the spot for the new line, since there is nothing hooked up to that spot normally, there should be no need for a fuse in the other spot, cause it's not being used for the car. Well it looks like you need a fuse in that other spot, which acts like a pass-through, otherwise there will be no power on the new line. Would have been nice if the instructions/box mentioned that!
Old Mar 22, 2005 | 01:50 PM
btvudoo's Avatar
I keep hearing ADD A CIRCUIT, how does it look like? Anyone have a picture? Thanks in advance, thanks for the tip also
Old Mar 22, 2005 | 01:57 PM
AdamNJ's Avatar
If no one else does it, I will try to post a picture later. I got mine from pep boys, and it's made by littelfuse . For our TL, you'll want the MINI version (ATO is a bigger size and won't fit).
Old Mar 22, 2005 | 02:18 PM
ludachrisvt's Avatar
Wants an M3 in
bwaaahahhahahahaha I didnt put this tip up because I wanted other people to struggle like I DID! It took me forever! I was so pissed!
Old Mar 22, 2005 | 02:22 PM
Canadian Mike's Avatar
This pic is from Zax123's site awesome install Link
Old Mar 22, 2005 | 06:02 PM
AdamNJ's Avatar
The link Canadian Mike posted shows the unit in action, and here's what the instructions and (opened) box look like:
Cost is about 10 bucks
Old Feb 2, 2016 | 12:26 PM
hulksmash604's Avatar
8th Gear
Awesome, thank you!
Old Feb 2, 2016 | 12:56 PM
riversnj's Avatar
just saved me so much trouble. this is awesome. thanks so much
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
ivan06106
Sep 26, 2015 04:38 PM
