Add an AMP
Old Dec 28, 2012 | 02:01 PM
cipdagr3at's Avatar
HASTA LA VICTORIA'
Arrow Add an AMP
Just doing some research before I go ahead and take apart my car for this.. Can I just use this ->PAC AOEM HON20 ADD RADIO AMPLIFIER AMP INTEGRATION INTERFACE HONDA ACURA
http://www.ebay.com/itm/271024006404...#ht_2029wt_838
with this ROCKFORD FOSGATE PBR300X4..??? Soundnoob over here.. Some advice will help!
Old Dec 28, 2012 | 02:49 PM
pohljm's Avatar
could be used, but absolutely not needed if the amp is chosen correctly. plenty of build threads for you to research on here.
Old Dec 28, 2012 | 04:09 PM
Sutitan's Avatar
I think itd be more useful to have a female connector of both the inputs and outputs on the amp, to just loose wires.
I want to add an amp, but not cut any of the factory wires. I essentially want to unplug the factory input to the amp, and plug it in to a connector that just has bare leads on it and run those to the amp.
Old Dec 28, 2012 | 06:45 PM
pohljm's Avatar
Go for it
Old Dec 30, 2012 | 05:36 PM
cipdagr3at's Avatar
HASTA LA VICTORIA'
Originally Posted by pohljm
Go for it
Thanks, I just wanted to make sure I didnt buy something that wouldnt work.. I know there is other options but I got some aftermarket speakers and wanted to go ahead upgrade the amp since my stock amp is fried... Thanks again
Old Dec 31, 2012 | 01:14 PM
pohljm's Avatar
Here is the unknown for me on that cable. I am not sure that I can select to have say the rear and center channels remain and pass thru to the OEM amp. I only need the front left and right full signals to go to the aftermarket equipment.
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
