Active Noise Cancellation - 07/08 retrofit
Old May 19, 2012 | 08:18 PM
sbarton's Avatar
6th Gear
I have a 2008 base with Nav. Wondering if anyone has retrofit the parts for the ANC system found on the 07/08 Type-S to a 07/08 Base successfully. I'm guessing the head units are the same, so if thats the case - One would need the ANC module that fits under the center speaker, the cable to connect it to the head unit, and the front and rear mics. I'm wondering if the wiring exists in the base for the rear mic, otherwise would need that also. Any ideas?
Old May 19, 2012 | 09:15 PM
ParaSurfer1979's Avatar
It's not worth it. The reason the Type-S gets ANC is because the exhaust droans. The base does not.
Old May 19, 2012 | 09:48 PM
DomGSR-T's Avatar
I have removed mine and I have not noticed any in cabin noise difference...
Old May 20, 2012 | 10:49 AM
I removed mine when i had my 08 Accord EX-L/navi i-4 and the stock exhaust rumble was noticeable but nice and mellow. I loved it. The droan was definitely there in the 4000-5000rpm range when on the high-way doing 70mph.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
