Accord Fog - HID Install wiring question
Old Aug 24, 2010 | 04:04 PM
VmtSquad's Avatar
"Advance"
Hi guys!
I just did the Accord Fog installation on my 04 and it looks great. I then ordered an HID kit to match our 4003k headlights. NO problem there...
Since we don't originally have some FOGs installed on our car I was wondering how to wire them. I them found this NICE picture that tells it all but leaves me with 1 question:
Connectors 3 : Connect to original headlight plug.....
Not really sure where this should be plugged in...any body got that answer for me ? And at the same time, where in the circuit should I install a switch if I want one?
Thanks GUYS!
Old Aug 25, 2010 | 03:26 PM
VmtSquad's Avatar
"Advance"
33 view, no clue?
Old Aug 25, 2010 | 03:28 PM
Sandals's Avatar
I think it if for if you want to wire it to your stock harness. did you try not using them and seeing if it works.
Old Aug 25, 2010 | 03:30 PM
Sandals's Avatar
Actually it is probably for the switch.
Old Aug 25, 2010 | 03:36 PM
thait's Avatar
I need a car in
do u have the oem accord fog switch? if so run the +12 signal from the switch to the red wire on plug #3 and ground the #3 black wire and u will be able to control it from the oem accord fog switch. i did that to two tl and it work fine including mine. this is for the original accord switch im not sure about the ebay ones.
Old Aug 26, 2010 | 11:26 AM
VmtSquad's Avatar
"Advance"
Awesome, yes I do have the OEM accord switch. Will have to find it in my stuff and give it a try. So I guess it's simply to tell the relay that the circuit is closed....
Thanks for your input, appreciate it !!
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
alan_rich
Sep 7, 2015 11:08 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
