Access Navi code 5 digits long please help!!!!!!!!
Old Dec 26, 2011 | 12:23 PM
TLmalloy's Avatar
I recently disconnected my battery cable and it says i need an access code, so i went on acuras page and got the code. They gave me a 5 digit code, but it will only let me put in 4 digits what should i do?
Old Dec 26, 2011 | 12:28 PM
Trunk Monkey's Avatar
Coolest A-zine Member
Radio Code is 5 numbers
Nav Code is 4 numbers
Old Dec 26, 2011 | 12:41 PM
TLmalloy's Avatar
Yeah i know that. I looked at the sticker and i put the 4 digit code in and it says its incorrect
Old Dec 26, 2011 | 12:46 PM
TLmalloy's Avatar
42556
1987
it said this is my code when i put the navi serial number on acuras website? I tried putting in the 4 digit and it didnt work. it also said my radio one is 25421. Is there any way i can skip the navi one and try the radio code to unlock the radio?
Old Dec 26, 2011 | 01:09 PM
I don't exactly know what you're doing here and why this isn't working...but the radio is put in with the 1-6 numbers near the cassete deck. The Nav (4 digit code) is put in on the nav screen. If it's not going....you've got the wrong number
Old Dec 26, 2011 | 01:25 PM
TLmalloy's Avatar
I dont see how i have the wrong numbers if i found all the numbers on the side of the glove box, and i got the same numbers from acuras website and it still says its wrong!!
Old Dec 26, 2011 | 02:12 PM
KN_TL's Avatar
Radio and Navi are totally separate systems. You should be able to enter the radio codes to get the radio going (entered via the preset buttons on the radio).
It's also possible that the deck was replaced. Pull it out of the trunk to see if the serial numbers match.
Old Dec 26, 2011 | 02:16 PM
TLmalloy's Avatar
Ohhh i put the code on the radio and it worked. The nav was replaced but i dont have the new code what should i do?
Old Dec 26, 2011 | 02:33 PM
KN_TL's Avatar
They should have given you a new sticker. Call the dealer with the new serial number. You'll have to pull out the deck to get to the serial number sticker.
Old Oct 21, 2023 | 09:06 AM
Justin0104's Avatar
So here's something unusual, i actually went to the website to get the code for my navigation, i put on the navigation serial number and it actually did bring back a 5 digit code 😅 it even says next to it "navi code". I've long since swapped out the oem head unit for an aftermarket one, but haven't been able to find the serial number for the navigation till today and then finding out somehow its a 5 digit code is concerning
Feb 25, 2020 09:57 AM
pozebly
Sep 23, 2015 07:30 AM
IndycarFaster
Sep 11, 2015 02:52 PM
darksky
Sep 5, 2015 03:11 AM
SUPRMN84
Sep 2, 2015 11:50 PM
