3GTL/2GRL Bluetooth Phones Compatibility...
Old Sep 16, 2009 | 10:27 AM
  #801
coykiam's Avatar
Originally Posted by zztoolzz
Did you get a HTC touch pro 2 paired with a TL? What year TL and which Cell phone provider. Just got a Sprint Touch Pro 2 today and can't seem to get it paired. I've had a Touch Diamond and the previous Touch pro and got them both paired but this new Touch Pro 2 seems to have some new bluetooth software.. Tried searching both ways and neither way found anything. Thanks for any help.
I have an 06 TL and got my HTC TP2 from Tmobile. Just turn on bluetooth on the phone and make it discoverable, then go thru the TL's phone setup options. From there on it should be straight forward. I was able to pair it with the car without any problems.
If I remember correctly, the MID will display the phone strength signal, battery level and caller ID. I'm not sure about phonebook since I haven't messed with that ever since I got the car 3 years ago...lol...
Old Sep 22, 2009 | 05:18 PM
  #802
frank358fr's Avatar
Hi,
I have a Acura TL 04 and a iPhone 2G. How can I pair the phone with the car..I tried but it didnt work.
Old Sep 27, 2009 | 10:19 PM
  #803
Capt_Crunch's Avatar
Just ordered the My Touch G3 from T-Mobile. Based on the G1 it appears that it should pair up fine. Anyone already pair up and can report on their success?
I'll post my results after I get mine and played with it for a bit.
Old Oct 1, 2009 | 09:43 PM
  #804
As promised. I just got the MyTouch. Paired up immediately and off the bat I have signal strength and battery strength. The calls are clear and no droped calls so far.
Since I have an '05 I'm not sure if there is anything else I need to look for. If there is, let me know and I'll check it out.
Old Oct 2, 2009 | 01:08 PM
  #805
BradE's Avatar
Paired the Blackberry 8900 with mine today. Works fine, signal strength and battery icons show up fine.
2008 TL-S.
Old Oct 5, 2009 | 09:06 PM
  #806
CaDesertRat's Avatar
Originally Posted by AM 2K5
I've been trying to pair my blackberry 9630 (tour) on my 05TL non-nav with no luck. Tried both search and listen function and still can't get it to work. Anyone successfully pair this phone in a 3rd gen TL?
i was able to connect to my '04 TL with no problem but some people complain that they can barely hear me. were you successful?
Old Oct 8, 2009 | 05:10 AM
  #807
clint999's Avatar
I flash/flexed my moto V525 to V600 45R firmware Still no battery meter only caller ID and Signal strength.
My friends SE T616 shows Battery, Signal strength and Caller ID in the TL
HFL sound quality is excellent on the V525 and recently flashed to V600.
Latest fireware on the SE T616 has fix the previously un-acceptable HFL quality. Now its excellent
Old Oct 12, 2009 | 02:17 PM
  #808
linger's Avatar
4th Gear
I just bought an Apple iphone 3gs. When I try to pair it to my 04TL, the Tl freezes right after issuing the password and the pairing in unsucessful.
I can't get the Tl off the password prompt even after removing the key from the ignition. I got desperate and disconnected the battery to reset the system.
I tried to pair them again, and once again, the system TL system froze. I did this 3 times in a row with the same result. Help please.
Old Nov 14, 2009 | 08:30 AM
  #809
fiftythreefly's Avatar
my iphone 3g paired great with the 05 tl. only issue is sometimes when i'm on a call before entering the car it tries to sync with the car once it's on and i lose the call usually. sometimes it just puts it back on the iphone but i've been very happy with the pairing of the two. too bad the 05 tl doesn't do stereo bluetooth as well
Old Nov 16, 2009 | 05:07 PM
  #810
Kostyan's Avatar
I am looking at getting a touch screen phone with Verizon Wireless and looking at LG Chocolate Touch. Does anyone have this phone with their 3g TL?
Also, does anyone have LG Versa, Samsung Rogue??
Old Nov 19, 2009 | 10:12 PM
  #811
ccin1492's Avatar
I can confirm that this is a problem. While attempting to pair my myTouch both the audio and MID freezes. It freezes in the discovery mode. The myTouch confirms the pairing, but displays unable to connect. I've tried multiple times with the same result.
Old Nov 23, 2009 | 07:31 PM
  #812
Mond's Avatar
i got the same problem with my 04TL and I-Phone 3G, it forze everytime when i pair it. Have anyone solve this problem?
Old Nov 27, 2009 | 08:27 PM
  #813
dodoman's Avatar
Bold 9700 works beautifully with 07 Type S. Was even able to transfer phone contacts to phonebook
Old Nov 27, 2009 | 11:52 PM
  #814
LatinSmoke 01CL's Avatar
Just in case anybody has the LG EnV Touch, it pairs perfectly and shows signal and battery icons. Was also able to upload phonebook.
Old Nov 28, 2009 | 04:16 PM
  #815
kfhughes's Avatar
'16 FBP Advance FWD
Motorola Cliq
Anyone tried pairing a Cliq? I've got a 2006 TL and was considering upgrading my T-Mobile phone to this, but only if it works with the TL. Thanks.
Old Dec 7, 2009 | 09:01 PM
  #816
tl jo's Avatar
just got LG Chocolate Touch on Verizon. Easy to pair, has battery, caller ID, signal strength and transfers calls. Have not tried the phonebook yet. So far I like it, only question is that I can't get five bars of signal strength but have not had any problems with calls.
I have 2005 non navi. Hope it helps.
Old Dec 10, 2009 | 09:36 AM
  #817
01clsstock's Avatar
i am so smart S M R T
Question Samsung alias 2
I have a samsung alias 2 and i cant get it to pair anyone have any luck with this phone? Model sch u750?
Old Dec 13, 2009 | 03:18 PM
  #818
kfhughes's Avatar
'16 FBP Advance FWD
Smile Success: Cliq paired with 2006 TL navi
Took a leap of faith (plus belief in the remorse period) and picked up the Cliq yesterday. It wouldn't pair out of the box, but from a Motorola Cliq user forum found that many other Handsfree owners had the same problem and it had been solved by upgrading the firmware to version 1.1.31. After getting T-Mobile to help push that to my phone, still no success using the normal pairing steps. I eventually put the Cliq in discoverable mode, had the TL search for devices, then made the Cliq search for discoverable devices. Presto; the Cliq found the TL's HFL and prompted me for the passcode. Entered it and everything was fine.
Old Dec 17, 2009 | 07:36 PM
  #819
seanforney's Avatar
Paired my iPhone 3GS a week ago with my 07 TL Type S and got contacts transferred no problem! Now I just need to figure out hoe to get my AcuraLink to connect.
Old Dec 20, 2009 | 10:04 PM
  #820
blazinginder's Avatar
TL SL ML :)
HOW did you do it...I cant get my iPhone 3GS to pair with my 07 TL-S??
I tried with the car one..pressed the HF key on the steering and said "pair phone" but it couldnt find the iphone and my iphone couldnt find the car
Someone PLEASE help, this would be VERY appreciated
Old Dec 20, 2009 | 10:58 PM
  #821
TL SL ML :)
Update...FIGURED IT OUT!!!...wow this is going to be a life changer now, when im in the car
Old Jan 3, 2010 | 11:30 PM
  #822
VieT916's Avatar
'05 TL non-navi----my LG Dare paired perfectly with the HFL and works perfectly. The only complain when testing was that people I talked to said my voice was clear but a little soft. Other than that, all functions were great, and it pairs automatically when I get into the car and start the engine.
Also, my girlfriend's HTC Droid Eris paired perfectly, too, and I must say that it's such an awesome phone!
Both of us are on Verizon, of course. . . .
Old Jan 4, 2010 | 12:13 AM
  #823
GeezerB's Avatar
What do you mean by that comment?
Old Jan 4, 2010 | 09:12 AM
  #824
VieT916's Avatar
Those phones are only available through Verizon, I believe. Someone correct me if I'm wrong, though.
Oh, and I haven't tried (on my Dare) to sync up the contacts or anything. I'm not sure if that's possible with my HFL system or the phone itself, but in terms of calling out and receiving calls, it works great! Now I just need people to call me instead of text to make this useful.
Old Jan 7, 2010 | 01:52 PM
  #825
leedogg's Avatar
RAR
HTC touch pro 2 on Verizon paired perfectly. shows signal & battery.
One strange occurrence that i noticed is that i *think* if the phone is still within BT range of the car, if I make outgoing calls, I will not hear the other caller because I think the call is still going through BT to the car instead. Only happened once, and I walked a distance from the garage to fix the issue.
Old Jan 10, 2010 | 09:32 AM
  #826
ribasaurus's Avatar
Has anyone successfully paired a Motorola Droid to a 3rd gen TL?
Old Jan 11, 2010 | 12:36 AM
  #827
TRK9's Avatar
I just got an HTC Hero (GSM - TELUS version : http://www.telusmobility.com/en/ON/htc_hero/index.shtml ) for Christmas. It pairs with my 2004 TL, everything works fine except caller id. It just displays "incoming call" or random dashes "- - ", unless I receive a call waiting beep while already on the phone, then the incoming number shows up.
Any AT&T users on here with an unlocked Hero from TELUS (Canada) with a similar issue?
I usually have the phone in my jacket pocket or in the console while driving, so I can't look at the phone screen.
Also I had a BlackBerry Storm (9530) also a TELUS version, unlocked and running with a Rogers SIM card on GSM. The strange thing with that phone, is Caller ID did not work for 50% off the calls on the phone's display but worked 100% of the time in the car's display. It was strange since the phone would display unknown caller, but I could see the caller's number on the car's MID.
Old Jan 18, 2010 | 12:06 PM
  #828
Oswald Vater's Avatar
Anyone tried pairing a Sony Ericcson 905a with the TL yet? I'm thinking of updating my 637t to this model and don't want to risk having it not work right. Thanks in advance for any info you can give.
Old Jan 18, 2010 | 03:51 PM
  #829
vuo69's Avatar
Nexus one
have any one able to pair the google nexus one with TL'06?
Old Jan 18, 2010 | 09:22 PM
  #830
borf42's Avatar
5th Gear
I was able to pair a Motorola Droid with a '05 TL. Works perfect.
Nate
Old Jan 19, 2010 | 03:45 PM
  #831
whitedrgons's Avatar
i try to pair my motorola droid with my 04 tl and it did not work. is there any APPs download to get it to work? i think it just the car? When I try to pair it to my 04TL, the Tl freezes right after issuing the password and the pairing in unsucessful. reset and try 3 time with same result. the system TL kept froze. any idea guy? plz.
Old Jan 20, 2010 | 07:34 AM
  #832
wrooni's Avatar
I have paired Nokia E61, E71, E75, N97 and HTC S743 with my '04 TL. They all work a little differently (may or may not show battery, etc), ut they all work. The N97 is quirkiest, always can answer but sometimes refuses to call (get "Call Not Allowed" message on the phone). One thing to remember - a lot of phones won't make a call if they are locked (N97, E75 for sure), and a lot of phones are set up to lock after a few minutes of inactivity. So you might go through the pairing, seemingly successfully, and then still not be able to make a call. Good Luck!
Old Jan 20, 2010 | 09:22 AM
  #833
borf42's Avatar
5th Gear
whitedrgons,
I have no additional Apps to assist with the pairing. What I did is after the TL asked for my password, I set my Droid to search for BT devices, since the car seemed to be sitting there while my Droid's countdown timer for "Discovery Mode" was running out. It came up with the "HandsFreeLink" and I told it to pair. Everything worked after that. Had a few conversations and it is very clear. Hope this helps.
Nate
Old Jan 20, 2010 | 04:23 PM
  #834
nate after read wht u did. i give it 1 more try and guess wht? WTF???
my navi screen act up crazy ( blink ON and OFF) and the car wont started. just dis- the battery and waiting for reset.
Old Jan 22, 2010 | 10:35 AM
  #835
borf42's Avatar
5th Gear
Wow, sorry to hear that. The only thing I can think of is that the nav and non-nav systems may be slightly different. I have a non-nav system. Should have clarified that... Did your car come back after the reset?
Nate
Old Jan 24, 2010 | 04:26 PM
  #836
DarkBlue2005's Avatar
has anyone paired a Storm with an 05 with Navi?
Old Jan 28, 2010 | 01:30 PM
  #837
Project X's Avatar
this may have been answered but i skimmed thru and did a quick search - is the apple iphone 3GS compatible with the onboard bluetooth in the TL?
Old Feb 4, 2010 | 12:33 PM
  #838
TheoLogical's Avatar
I paired my Google HTC Nexus One with my '05 TL today. So far so good.
- I see the signal strength and battery indicators.
- I was able to make a call.
Old Feb 4, 2010 | 06:22 PM
  #839
PaloLargo's Avatar
5th Gear
Blackberry's are a major pain when syncing your phonebook......
Old Feb 6, 2010 | 08:07 PM
  #840
westsideaccord's Avatar
5th Gear
My Samsung Instinct, compatible but dont know how to use phonebook?
