3.9 Navi Hack
Sorry, confused
Hoping I can get some clarifications. I have the 3.9, want to hack, but I have been reading too many threads I think. I did download the files for my car, but they are .rar files, and now I am lost. Any help on step by step would be GREATLY appreciated. Thanks in advance.
U need WinRar to decompress the files. Google it for the trial version.
Once you have files decompressed, you need to burn them to a CD, then follow the instructions you've already read to apply the hack.
I did get the Back.bmp to work, but it seems the OK nag and others did not take. I did use the WinRar to decompress. What then do I burn to the disc (you mentioned that they are already modded, so I am to just burn these to the disk, then install in my Navi-DVD?). Thanks again for the help.
I follow all the instruction to the T. Both files and decompress them from rar files to bin. Using a CD-R. I still get the "please check your disc" message instead of the error message. Any thoughts from you tech geniuses?? What am I missing?
You should be able to use the files posted by maddsiick above just as they are. If you want to change the bitmap, I recommend the DumpNavi GUI program for ease of use. Just make sure you remove the tick from the "remove nag screen" option box before running it. I think many problems people are having are related to applying the no nag to an already hacked navi.exe----it doesn't like that.
^^ you only need one of those files. depends which one your car uses. some cars use the BNHH401A.BIN file and some use the BN2HH12C.BIN file. for example, mine uses the BNHH401A.BIN file so i took that file, modded the startup screen wallpaper to my own image, then burned it to a cd with the loader file as well and then follow the instructions for the previous hacks.
If you dont know your version file do the following:
1. Hold down MAP/GUIDE, MENU and CANCEL buttons for 5 seconds
2. Select Version
3. Hold down MENU for 5 seconds.
4. The loaded BIN file name should be listed under loaderfile i think. its going to be one of those two files i listed. If your navi says its the BNHH401A.BIN file then thats the one you use from the links in the previous post, if you navi says its the BN2HH12C.BIN file then you download that one.
2. Select Version
So i downloaded all 3 versions and all the files are supposed to be .bin files, correct?
And the startup screen is supposed to be a .bmp file? I do design all day long and can resize whatever, but I can't find the bmp/bitmap file anywhere
And what's the loader file mygrlsTL is talking about?
Nevermind, i reread this whole thread carefully. I did the mod in less than 2 minutes. The trip stats are awesome as you can see the instant Mpg.
I still can't find the editable .bmp file tho. I'll do a search. thanks for hosting the files!
If someone can send me all the files I need for the 3.9 hack, I will pay them for it. I am confused as to what files I need to download and what type of disc to burn them to.
My email is vogelbacker@gmail.com. Any help is much appreciated. Liek I said, I am willing to pay!
ok, I downloaded Maadsiicks files, I use BN2HH12C.BIN version. Burned the two files using nero to a memorex DVD-RW, inserted the hack disc, did the three finger salute, pressed version, then load disc, display said "check disc". Removed hack disc, reinserted 3.9 disc, but ok button still present...I'll try again, maybe I should use a CD versus DVD...any other thoughts?
COL G
COL G
I am having the same exact issue. Does it need to be burned to cd or dvd? I have tried everything!
Ok so here are the links to the files that bibo136 posted a while ago for version 3.8, these bins also work for version 3.9. I have tested them and they do work, OK screen is removed, trip computer and A/C controls from the navigation screen and you can always add your own custom image the same way as posted before.
3.8 and 3.9 Navi Hack for A/C, Trip Computer and OK Screen Hack
BNHH401A.BIN version
http://rapidshare.com/files/258389255/38_BNHH40A.rar
http://rapidshare.com/files/24758025...ura_screen.rar
BN2HH12C.BIN version with top gear startup screen
http://rapidshare.com/files/24597285...i_and_trip.rar
I must be riding the short bus today...I hit the "Download Now" button and see the timer going...yet, no file. I'm running Mac and I know the firewall at work won't let me get to the website. What's the deal?
i need the files.. I've been browsing EVERYWHERE and will be disappointed if someone sends me links on this site where they are still active. I have a 2006 TL with the Orange 3.9 Disk. Thank you all.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
SUPRMN84
Oct 7, 2015 09:46 PM
