2aug wire through the fire wall?
Old Nov 8, 2008 | 04:47 PM
PHUQ2's Avatar
Were is a good place to run a 2aug wire through the fire wall? I have an 07 acura TL type S.
Old Nov 8, 2008 | 07:28 PM
Kracker's Avatar
05 TL
See this thread... It really helped me..
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/diy-aftermarket-amp-install-speaker-install-audiocontrol-matrix-install-w-pics-580314/
Answer is in the first post.
Old Nov 9, 2008 | 08:18 AM
PHUQ2's Avatar
well lookie there it is. Thanks kracker. There must be less space under my hood with the 3.5L. I had to remove the bolts from the fuse box so that i could see the gramet. Now I just hope that the 2 guage wire will fit through the hole. after I figer out how to get my hands to the firewall. Im not japaneese but I do have small hands.
Old Nov 9, 2008 | 06:19 PM
CSWBiggs's Avatar
u guys kill me...run it through the factory grommet driver's side with the rest of the chassis harness...poke with a flathead screwdriver bottom right hand corner of boot...and feed into the engine bay...nuff said...
tip...use a bit of windex and lubricate the cable before you pull into the engine bay...makes it alot easier not to mention...reduces the chances of you tearing the boot...i have 2...2AWG wires running through the boot...best of luck
-Jason
Old Nov 9, 2008 | 07:04 PM
PHUQ2's Avatar
I was able to run the 2 gauge wire through the hole with room to spare. I spent most of my day building a box to hold 2 L7 15's D2's. the box is 7 cu.ft. and takes up the whole center of the trunk. I will be running an autotek mx2000 class x amp. This should be enough power to rip the trunk lid off of its hindges. he he he!
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
