2006 Nav Issues!! Please Help
I recently bought a 2006 Acura TL. Radio works, but the nav has the dreaded “please check your disk” message. The eject disk button is NOT lit up. I have tried to wiggle around the nav connections, checked #7 and #32 fuses, unplugged the battery for half an hour and plugged it back in. All with no avail. The guys I bought it from said the nav stopped working after they replaced the battery. Thanks in advance for any help!
Anyone?
Just 5 connectors. The one on the bottom right (as you look at it from the back) remains empty. I just had my drive serviced by Alpine to fix reboots, FI-ECU and numerous other errors in diagnostics, reboots, etc. I just posted about that experience.
So I got a new unit off of eBay and the same thing is happening. There is no power to the player. The same check disk message is appearing except when I remove either one of 2 plugs. Not sure which harness gives the module power. Any ideas? Maybe it’s not plugged in up further in the car.
eighch
18
05-05-2018 06:45 PM
Skunkworkz
1G RL (1996-2004)
03-03-2015 05:57 PM
jswinslett
07-05-2014 04:50 PM
