1 12" or 2 10" ported box enclosure.
Hi eggy. Since you live in the bronx do u know of any shop that would make a custom trunk box or do u make them. I might go with dc audio level 4 or a tc sound. Why would you choose sealed over ported box? I thought ported would you louder spread out bass
Neither
I had to get my done online.
Here's the guy who did my box
http://www.caraudioclassifieds.org/f...play.php?f=121
Ported is louder, but ported boxes are BIG
1000+ watts is gonna be loud regardless of what box it's in.
Neither
Single 10 like the Alpine-R is more than enough for good clean bass and small enough to conceal in the truck without taking space. I bet a single 10 Alpine-R with Alpine mono amp 400rms is more than enough to make your trunk rattle. I ran a single Infinity 12 with Alpine mono amp 400rms in my last car and can never turn the sub higher than 50% as it would rattle my back window and mirrors to the point where they are useless.
something like this but with a single 12, the box made to spec, this is something like what i'm looking for,
http://cgi.ebay.com/04-08-ZEnclosure...efaultDomain_0
i have a type r 12" with a 450w rms alpine amp in a ported box. it does not sound clean, it sound very bad and is taking much space. i learn the hard way that to make a sub sound good, you need to have the proper sub box made to spec if is either sealed or ported. so this is what i'm looking for, having a box made to spec but blended in with the trunk.
You can build that simple box yourself. If you're looking to prioritize your space saving then go with 1 = 12" sub. Make sure to have it built to spec. If you're looking to save space you're option is now limited so ported now is not really a choice for you since ported boxes are ussually bigger. Again remember you can get top of the line speakers but if they are not set in right box and not tuned right it will be just another cheap overpriced speaker from radio shack .
i cannot build my box since i have ZERO experience with wood cutting and don't have the tools.
Are this spec good for a type r 12 made to spec and tune to 32hz
http://cgi.ebay.com/12-ALPINE-TYPE-R...efaultDomain_0
i also see that adding a second type r on a made to spec porter only ad about 4 more inch all around to the box. i think it would be a better idea if i go the 2 sub route since 1 type r box in ported box take almost the same space.
1 10" W7 in the correct ported box will blow most dual 12" setups away in both SQ and SPL.
It may, however take up nearly as much space as one 12" in a sealed encloure but chances are it would perform much better.
I learned the hard way when I first got my two 12" W6s in a sealed box with 1,200 watts. I listened to a co-worker's single 10" W7 1,000 watts ported and it blew mine away in every category. I was embarassed to say the least. I was amazed that it sounded so much better and I was amazed that it was sooooo much louder.
I believe the w7 is also more efficient than the w6.
I'd go 12 sealed in op's case
He'll benefit from more cone area and save space
you are so right, that is why my type r sounds like crap now. would you recommend just keeping the type r and getting a custom box made to spec and give at least 600rms. i want to save space but i also prefer having a ported box.
look how tiny that port is
ports that small= suspect boxes
this is a legit ported box..ugly..but it got the job done till i got something that looked better
eduardmc: Keep your type R's and put them in the right box and tune them right. Then decide if you need another sub later. It's all about enough rms power feed and tuning. It's not about how expensive the sub is ported or not ported box. Most tards around my neighborhood have all juice and no tune so that equates to ineffient juice suckers and a shitty boom boom all around the street Then you got these guys wastin' all that money on their "super rms eating subs" then they roll up to me at night at a stop light and all I see it lights dimming and rattles from hell. I've had some pull up and ask me what i'm running. hahahhaha All I have is 1 Rockford Fosgate Punch P3 P3D412 in a sealed box. Not saying my shit is the bomb but it's respected enough where I rip the hell out of 2 15's. My point is tuning, right box, proper juice otherwise it's just another expensive radio shack crap.
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/perfect-shallow-mount-box-sub-under-%24300-788732/
or this 500 rms
Dogmatic Dinosaur
This is good advice. Put FI Q, SSA Xcon, RE XXX or the like (there are many good subs to do this) in a 1-1.25 CuFt sealed box, according to spec, with 1000W, or so. You will likely be happy with the sub in any position (rear corner, front, etc.). This should likely sound great and is easy to get right.
If you need trunk room, this works great.
TL owner
here is a box i built for my 12w6v2 before i left Hi-Fi built to Jl's specs, the port isnt huge
LOL, Are you serious? Ive built plenty of custom boxes for type R's at 2.00 to 2.75 cubes cubes and it was enough for the type R's to slam. Bigger isnt always better it just makes it more efficient generally. Woofer displacement all play a role with the size of the box etc.
look how tiny this port looks, though
you know how peaky a r would be in a box like that.
Your box looks a tad on the small size too considering jl's usually like bigger boxes.
TL owner
12w6v2 only calls for a 1.5@32hz by jl's specs and thats what was built... I could have built a 3 cube one note wonder but thats not needed in the application i was running in my car at the time. if you dont have the power then a larger box is good but if you have 1000+ watts why not so with a mid sized box with a low tune so you can retain the SQ and still drop the low notes accurately. A large Box and port doesnt always=better sound
because building a smaller box with a tiny port makes it peaky
I've gotten flatter responses with jl's in bigger sealed boxes.
and the w7's? they love huge ported.
Same thing happened over at re with the xxx
They advertised that the sub only needed 2 cubes sealed
Then caraudiomag did a review and noted that the 12 needed 6 cubes sealed to get it flat and get any respectable output out of it.
well i went with a 12" ported box 2cube (after sub placement) tune to 30hz. will be running this box with a tc sound LMR-12 and around 1200-1400 rms to it.
i wanted to save space but i also wanted the same or better bass like i had before. After all my research i had to give some trunk space to acomplish what i wanted. I remember my jaw dropping for 3 years everytime i heard my tc sound tc-9 single 12 sub. People Music was much enjoyable before at low volume you will still get a deep low clean bass.
take it from a guy who had 2 12's in the back. do a single, high powered 12. 2 12's take up too much room in the back - whether it be 12's or 10's. a single 12 is your best bet. gl
TL owner
InFaMouSLink
10-30-2015 09:43 AM
