06 TL Sound System Question
Old Jan 29, 2007 | 01:23 AM
dre23's Avatar
I got my 06 TL a couple of months ago. I just felt that the system was not as good as the second generation was in terms of the bass.
all the second generation TLs have BOSE system on them which sounds better than the one that I have on my 06 TL in terms of the bass.
Is there an options to choose BOSE system in our third generation TL?
Old Jan 29, 2007 | 10:33 AM
brettallica's Avatar
Godfather of Chrome
From: Santa Cruz, and yes I'm a hippie with retro 1970s sideburns and a chrome fetish
Why don't you try putting in a different sub for starters? My guess is that would satisfy you at least temporarily.
Old Jan 29, 2007 | 10:58 AM
Kennedy's Avatar
OMGWTF4THGENTL
Not that would be cheap and easy...
It's actually really cheap to upgrade the TL stereo with some better components.
Tweeters:
Infinity 1011t: $50
Center Channer:
Infinity Kappa 32.7 $35
Doors and rear deck:
Infinity Kappa 62.7 $180
Sub, I'm going this route:
Drop in JL 8W3v2 and JL e1200 amp... $150
https://acurazine.com/forums/showthread.php?t=152357
Old Jan 29, 2007 | 11:51 PM
dre23's Avatar
The problem is, I don't want to run wire to put amp and sub on my car.
I just don't want to take out the dash panels.
Old Jan 29, 2007 | 11:52 PM
dre23's Avatar
Tweeters:
Infinity 1011t: $50
Center Channer:
So, do you need to run amp for the subs? The vocal sound is good enough for me, but I can't stand with the bass.
Old Jan 30, 2007 | 12:08 AM
Godfather of Chrome
What I meant was: why don't you just take out your factory sub and get one that is more efficient? That way, your bass will get louder at a lower volume and you'd probably be able to avoid cranking it to get good bass, which could damage the factory speakers. You could probably do just fine with replacing the speakers themselves and not worrying about installing amps.
Old Jan 30, 2007 | 06:33 AM
Kennedy's Avatar
OMGWTF4THGENTL
Reread my post...
I'm replaceing the stock sub (in stock location) with a JL 8W3v2 and powering it with a JL e1200 amp. That should give plenty of bottom end.
I'm not looking for 180 dB system or a trunk and teeth rattling experience like many of the bling systems folks are into...
Old Jan 31, 2007 | 12:27 PM
dre23's Avatar
That's probably what I am going to do. Changing the subs..
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
TLDude876
Dec 28, 2016 03:18 PM
Iain MacLeod
Sep 17, 2015 01:01 PM
