05 Navi/radio issue
Old Feb 26, 2021 | 08:53 AM
David_BNSF's Avatar
2005 TL
05 Navi/radio issue
Got in my 05 just a little bit ago after getting off work. Navigation screen goes through its thing with the disclaimer and I notice I can’t press the “OK” button. Screen then goes dim and tried to turn on the radio and that doesn’t work either. Ended up pressing the buttons on the steering wheel for navigation voice command and the disclaimer screen comes back up with the “OK” button, still can’t press “OK” and then after a bit then the screen goes dark. I can’t even get to the diagnosis screen either. Checked the disc in the trunk and it’s fine. Any ideas, thanks in advance for any input.
Old Feb 26, 2021 | 08:56 AM
perhaps the touchscreen is not touch any more????????????????
ie: it's broken...
I came to that conclusion with the process of elimination provided the given context....ie; works with steering wheel controls
Old Feb 26, 2021 | 09:03 AM
David_BNSF's Avatar
2005 TL
ie: it's broken...
That’s a bummer. Might have to go check the pick n pulls for one. Wouldn’t think it would kill the radio too.
Old Feb 26, 2021 | 09:30 AM
A screen/monitor isn't apart of the radio...it's just a display
again, only coming to that conclusion based off the context of the post...ie; works with steering controls but touchscreen does not interact with touch.
You might have to do further testing to figure out if the screen really is bad
Old Feb 26, 2021 | 05:11 PM
csmeance's Avatar
does the little joystick (silver in the center) work?
ShiggityShatz
6G TLX Problems & Fixes
17
Feb 28, 2021 12:20 PM
puma_18
Mar 7, 2014 09:31 AM
stbxvd
Feb 19, 2011 02:46 PM
5AT04TL
Sep 24, 2005 01:10 AM
bamaboy1974
May 29, 2005 01:33 AM
