04 TL nav screen blank
So my nav screen is completely blank. The radio still works and I can change the channels and adjust the volume. I just can’t see it.
From the research I’ve done it sounds like a DVD issue in the trunk. After checking the DVD player I can see the LED light is not on. I’ve checked the connections and all associated fuses and all those seem to be ok.
I know you can send it back to Alpine for repair, but they currently want $368 at minimum to do the repair if needed. I’ve been looking at replacement units on EBay and that seems like a better choice since most of those run about $200.
1st, Is there anything I may have missed as far as diagnosing this blank screen?
2nd, has anyone had success in ordering a used DVD from EBay?
I have the same issue currently but started differently. Factory Nav DVD drive yields a checkerboard flashing picture that still dims - everything else works except the secondary top screen.
Bought a "known working DVD drive" from eBay and that yielded a blank black screen that also dims - all other things remain the same.
Bought a "known working Nav Screen" from eBay and no change to any results with both drives (have tried all combos). Wiring seems solid, I checked all wiring at the back of the DVD drive and looks good. No clue the issue, but likely the DVD drive which I got a quote from Alpine for just like you.
In hindsight, instead of wasting ~$400 on eBay, I would have rather wasted ~$400 to Alpine to at least ensure I have a working DVD drive.
So I took a chance and got a used DVD player on EBay for $240 and it worked! The display is back and working.
Although in retrospect the only thing I really got out of this is I get to see the radio station channels. I’m not really gonna use the nav for anything because I use my phone. So I probably should have just paid a little more and got a nice aftermarket radio with Bluetooth. Something more modern. Oh well.
JcHuang563
Jun 5, 2012 01:25 AM
WDP-Acura TL
Jul 30, 2004 10:52 PM
