[Full Guide] 9.7in Android Touch Navi Upgrade (Tesla Style) for Acura TL 2004-2008
Old Oct 2, 2023 | 07:56 AM
  #201
Purplepilot's Avatar
5th Gear
Thanks. Problem solved!!!!
Old Oct 2, 2023 | 08:10 AM
  #202
5th Gear
[QUOTE=Ziofen;16907899]Try switching the #8 connector and the one that plugs directly into the unit.
Just want to confirm…..
with a “low unit” (ie. no navigation stereo)….you end up with the green unused plug in the center back of the new unit?
thanks again
Old Oct 9, 2023 | 08:41 AM
  #203
OnlyDaanish's Avatar
Originally Posted by ashkuz
Did you ever try this? Has it worked for anyone else? If so does anyone have a guide for doing it with the Navitech unit?
@ashkuz
I have't tried that wiring yet, but I did see a video a while back where it worked. The noise filter did absolutely nothing for me.
Originally Posted by icemint.asa
You can change the it to °F in Settings>Factory Settings>Car Agreement then reboot for the newer firmware ones. You can also upgrade the firmware if you have an older version. Though, not through smooth ota but easy nonetheless
@icemint.asa
I will ask my NaviTech contact for any updated firmware files and see if it fixes that for me. Your clock is in F not C?
Old Oct 9, 2023 | 10:29 AM
  #204
Latest Firmware Update
I received the latest update from NaviTech (02/2023)!
Files can be found here: https://www.mediafire.com/folder/0hf...%40onlydaanish)
If anyone experiences and issue where the screen is rotated after the update, there is also files for the fix in the same Feb 2023 folder
Old Oct 10, 2023 | 03:11 AM
  #205
mariusz439's Avatar
Is it applicable to all units? (suppose unit is the same and differs with wiring, but it's wiser to confirm 😉
Old Oct 10, 2023 | 05:42 AM
  #206
seems to work with my unit fine and mines the 2020 version
Old Oct 11, 2023 | 12:50 PM
  #207
mariusz439's Avatar
One more question. Do they provide update log? I'm just wondering if it's worth of spending time on backing up what I have in case of failure.
Old Oct 11, 2023 | 12:56 PM
  #208
I don't see an update log, but im not great with android software files so I wouldn't know. I will say this, I forgot updating basically restores the device. It will delete all ur apps and settings but keep your stored files. Also, there is no ACURA boot up logo in this version which is a tiny thing and doesn't really matter but still bugs me haha.
Also: They change the A/C controls to be a full screen app instead of a little menu that slide up from the bottom.
Old Dec 3, 2023 | 08:13 PM
  #209
TLTypeSDream's Avatar
Does anyone know if / where I can buy a replacement harness?
Old Dec 3, 2023 | 08:17 PM
  #210
For the unit specifically? DM me I can ask the manufacturer
Old Dec 3, 2023 | 09:19 PM
  #211
Yup, harness for the unit. DM sent. Thanks.
Old Dec 4, 2023 | 06:52 AM
  #212
I was able to find it, here's the link if anyone would need it. Fairly cheap at $15 USD
https://www.aliexpress.us/item/32568...yAdapt=glo2usa
Old Dec 8, 2023 | 08:16 AM
  #213
@TLTypeSDream Nice! I actually contacted the manufacturer and confirmed with her that is indeed the one.
Also everyone, NaviTech has let me know that there is NO Extra Charge for the Red LED version of the Navi if you just let her know in the order message. I've also let her know that maybe a WHITE or Multi Color version would be better for all this money we're paying for the navi as it is.
Old Dec 8, 2023 | 09:45 AM
  #214
Is there an option to buy a kit to convert the blue LEDs to red?
Old Dec 8, 2023 | 11:11 AM
  #215
I don't think so :/ I can ask
Old Dec 17, 2023 | 02:52 AM
  #216
1low3rdGen's Avatar
Can't message you
@OnlyDaanish acurazine won't let me PM you, I have questions about the firmware update
Old Dec 17, 2023 | 05:58 AM
  #217
Weird. @1low3rdGen u can always ask try question here in case others have a similar one.
Old Dec 17, 2023 | 12:04 PM
  #218
1low3rdGen's Avatar
I downloaded your software as my unit has a major glitch of getting hung up in an app then crashing and restarting completely.
So after downloading the software I shoved the files on a usb stuck it in the usb cord and no magic happened. So I then go back to the computer unzipped the files. Back to the car and still no magic. Both times I restarted the unit. Is there something I'm missing?
Old Dec 25, 2023 | 08:38 AM
  #219
@1low3rdGen I thought I replied to this but it seems to have not gone through.
The software files should be all on the root of the stick (not in a folder). Try both usb wires because one of mine doesn't work with usb stick so im assuming its only one that works. Make sure the card is on Fat32 format. You shouldn't require restarting it should pickup on the files automatically after plugin.
Old Dec 28, 2023 | 07:51 PM
  #220
Finally got it installed and working well! How do I change this red car? I'd like to just remove it and have no car.
Old Dec 28, 2023 | 08:14 PM
  #221
you should be able to change it to the Acura. Or use my guide to download a custom launcher.
https://acurazine.com/forums/3g-tl-a...008-a-1002148/
Old Dec 28, 2023 | 08:18 PM
  #222
Nice write up on that launcher. How would I change it to just Acura?
Old Dec 28, 2023 | 08:22 PM
  #223
I’m pretty sure you just hold down on the car logo and it should let you edit.
The units come with the Acura photo u can change to in the internal storage
Old Dec 28, 2023 | 08:27 PM
  #224
Ah OK. I had tried that, but I don't get any options as to what I can choose.
Old Jan 7, 2024 | 12:46 PM
  #225
jjacura911's Avatar
Carlink 2.0 isn’t working
I have the newest model of the Tesla screen. Currently, the carlink2.0 app will launch and immediately crash without anything occurring. I’ve tried removing cache and native files to no success. It randomly stopped working yesterday pm after working in the morning. Thanks in advance
Old Jan 8, 2024 | 08:26 PM
  #226
jjacura911's Avatar
I factory reset the device and everything is working just fine
Old Jan 21, 2024 | 09:42 AM
  #227
RxWorld's Avatar
Anyone have any parasitic battery drain with this unit? Trying to do some troubleshooting and this is the only new factor.
Old Feb 22, 2024 | 11:04 PM
  #228
Sledgehammer_01's Avatar
5th Gear
Got this unit installed in my 3rd gen and after some tweaks I'm relatively happy, however I'm bummed about the audio control. Why on earth does it only have two channels out???
Old Mar 2, 2024 | 12:24 AM
  #229
icemint.asa's Avatar
​​​​​​I have one for a different launcher for our unit with Acura. I can also unpack the launcher you're using and replace it with our Acura TL.
Old Mar 2, 2024 | 07:03 AM
  #230
does the launcher replace the entire operating system that's built in, or just like an add on? Im pretty new to some of this kind of stuff.
Old Mar 2, 2024 | 10:38 AM
  #231
It would only replace the same launcher (which has a different car). Not the one in your pic. However, I don't think the navitech software has this launcher by default. I pulled it from the software on my device since I am using a different firmware than the original Navitech one. All this changes is the home screen. You can just install it like a regular apk. This is what it looks like (blank box is for whatever app you select, such as Maps)
Old Mar 3, 2024 | 07:58 AM
  #232
Lodaks's Avatar
Still temp in Celsius on the clock display? Android auto works great in full portrait mode
Old Mar 14, 2024 | 02:52 PM
  #233
5th Gear
It would be really nice to get a pinnout diagram for the backside of this unit. There are "Subwoofer" settings but I have no idea where the sub out line is...
Old Mar 18, 2024 | 09:05 PM
  #234
@RxWorld No there shouldn't be any. Ive had it for 4 years without any drain what so ever.
@icemint.asa This is a realy nice launcher, much prettier than the one I released. can you send over the files. I'll add it to the folder
@Lodaks Yes the clock is always C
Old Mar 19, 2024 | 08:57 AM
  #235
ashkuz's Avatar
5th Gear
Audio Buzzing
Any fixes yet for the constant audio buzzing sound? This is the last thing with the unit I really want to get fixed... Thanks!
Old Mar 21, 2024 | 11:11 AM
  #236
H23Accord's Avatar
iWhine
In order to change it you...
1. Go to the settings menu.
2. Go to the crossed wrench and flat head screwdriver and input the code.
3. Go the "car model" option.
All your options are there even though not well labeled so you will have to go through each one to figure out how you want yours setup. Mine is setup with no car using this layout...
Can box type: LZ(HZ)
Car brand: Benz
Car model: B200/VIANO
Can box: HZ.XP
Looks like this on mine currently but tend to change it when I'm bored. I might have to check out some of the new versions some of the guys here have posted.
Old Mar 21, 2024 | 07:49 PM
  #237
Car brand: Benz
Can box: HZ.XP
Bud... That's the canbus settings. A/C controls on the head unit won't work anymore if you change from the one meant for the car. It will change the UI but the whole reason to have a vehicle specific unit is now null..
Old Mar 21, 2024 | 08:56 PM
  #238
Here is the no car version you wanted.
nocar_190001002_com.android.launcher4.apk
Here are some other variants I made along with the original launcher6 and my anthracite launcher59 variant. Just install them like normal apks.
Anthracite (launcher4)
(anthracite)190001002_com.android.launcher4.apk
Blue Pearl (launcher4)
(bluepearl)190001002_com.android.launcher4.apk
Silver (launcher4)
(silver)190001002_com.android.launcher4.apk
Silver Remix (launcher4)
(silverremix)-190001002_com.android.launcher4.apk
launcher6
190001021_com.android.launcher6.apk
@OnlyDaanish
Anthracite (launcher59)
190108059_v_com.android.launcher59_acura.apk
Attached Thumbnails [Full Guide] 9.7in Android Touch Navi Upgrade (Tesla Style) for Acura TL 2004-2008-screenshot_20230823-105328.png
Old Mar 21, 2024 | 09:07 PM
  #239
It’s not possible to fix it. I’ve seen a video where someone bypassed the unit and cut the speaker wires from the amp to the RCA directly. I’m not so sure how plausible that is to do with our unit.
Old Mar 22, 2024 | 01:56 PM
  #240
H23Accord's Avatar
iWhine
Ah thank you for that insight. Part of the reason I chose that one is because I don't use the A/C controls on the unit and thus prefer the lack of those visible controls. But outside of that are you saying it changes other features as well? If so, what else?
