wrong gear questions
Old 12-14-2008 | 07:11 PM
akinin11's Avatar
i have an 2005 tl 6 speed 79 k on it last week i down shifted into a wrong gear form 3rd into 2nd and redlined to 8k before i realize my mistake first time i ever did that an i had my tl since new , either i am imagining but now it idols alittle rough, engine runs good, no check engine or anything and i put about 500 miles since i did that what should i do. Are my valves ok or the plugs maybe thanks for all your input i am new on this forum please give me some info
Old 12-14-2008 | 07:22 PM
nfnsquared's Avatar
If you went to 8K, I'm afraid to say you're probably screwed. More than likely, it's only a matter of time before your engine blows. I'd have your car towed in and prepare to shell out some major dollars for a fix.
Old 12-14-2008 | 07:35 PM
01tl4tl's Avatar
investigate! pull the plugs and look at the oil
Do a compression test and if needed a cylinder leak-down test to determine if there is valve damage.
Have the codes checked in case there is info there
Old 12-14-2008 | 08:01 PM
Timeless's Avatar
If you hit 8k rpm you're probably in trouble. Follow 01tl4tl's advice and have the engine thoroughly inspected ASAP. Drive your TL gently until then and carefully there after.
Old 12-14-2008 | 08:11 PM
Bearcat94's Avatar
AZ Community Team
Drive as little as possible. Straight to the dealer, if that.
Old 12-14-2008 | 09:48 PM
MichaelBenz's Avatar
CTS-V Import Slayer
Damn....8000 rpm is not good on these motors....and unfortunately your car likely recorded the whole event. Acura will not warrantee this kind of thing at all as they will pull the event from the computer and brace you with it. I have seen it happen.
Sorry this happened to you. That sux!
Old 12-14-2008 | 11:30 PM
ussi's Avatar
I (don't) whine.
like 01tl04 said its more than likely that you might have bent your valves. do a compression test. CEL might take a few days to come on...
Old 12-15-2008 | 07:04 AM
01tl4tl's Avatar
"It idles a little rough now"~ thats all we needed to know
Hope you have $2500-$4000 laying around
If it only bent the exhaust valves- towards the low number,
banged a valve into a piston hard enough and it can shock wave damage down thru the rod bearing and damage the crankshaft.
May as well get a crate engine- thats a new engine that arrives in a wooden box= crate
Its really cool to see a piece of the engine sticking out the side~
Makes it easy to diagnose at least!
Old 12-15-2008 | 07:20 AM
I mis shifted my 6MT....long story short was supposed to go into 4th but went into 2nd instead. I think I probably hit about 10,000 RPM's and it felt like i hit a wall. Either way, I had $4100 worth of damage. My CEL didn't come on right away but the idle was rough. A little while later my CEL popped on. My valves were bent and had both my heads replaced on the car. My exhaust sounded like a put put put when at idle. I didn't go through Acura for the repairs. They wanted $700 for a "tear down" to tell me what was wrong w/the car. I went to a private mechanic, hooked it up to the OBD and said immediately that I bent my valves and needed new heads. It took about 2 months for my car to get repaired. Most of the time was spent waiting for Acura to send the heads from the factory. Good luck.
Old 12-15-2008 | 07:49 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
as stated before, worry should be your number 1 priority
the quicker you get her to a shop, the better it will be on ur wallet
Old 12-15-2008 | 05:03 PM
frosty ride's Avatar
I thought there was a rev-limiter?
Old 12-15-2008 | 05:44 PM
vinnier6's Avatar
that was going to be my question...
Old 12-15-2008 | 05:53 PM
Timeless's Avatar
There is a rev limiter, however it will not stop the engine from literally being forced to operate over red line. Even the owners manual specifies this. The rev limiter only works when you are driving in gear and bring the rpm's too high before shifting.
Old 12-15-2008 | 06:40 PM
Adobeman's Avatar
The DVD-A Script Guy
"It's worse than that, he's dead, Jim."
Sorry to hear about your mistake. You're not alone, others have "floated the valves" doing the same thing. Ain't no rev limiter in the world that's going to hold back that amount of energy being spooled back into the crank.
Old 12-15-2008 | 07:08 PM
01tl4tl's Avatar
on the MT cars the rev limiter can only operate on the up rev to upshift
No way to control it on a downshift- especially missed shift
With the AT cars- they can limit the revs by not allowing a requested downshift- its all microswitches and calculations
Unless you are racing there is no reason to be speed shifting,especially on the downshift!
The trans downshifting should be used to be in the correct gear to accellerate off the corner- the BRAKES are to slow the car down
Old 12-15-2008 | 07:10 PM
01tl4tl's Avatar
Have you gen3 guys ever read your owner manual? With winter making a dramatic arrival- now is the time to understand and practice with the ABS and TCS systems
The newer the car -the more complex the system and its abilties of applying one brake to tighten a turn or control throttle etc
Dont have a book???- here they are for free from acura https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
click year then model
Old 12-15-2008 | 09:36 PM
ussi's Avatar
I (don't) whine.
i was going to do this but haven't done the swap yet. the type-S valve springs have a much higher spring tension rating and should protect your valves a little better. if you're going to do a head swap might want to look into that along with type-S cams. I have an extra set of type-S heads lying around which i was going to use for parts but i need an excuse to pull my heads again, which ain't cheap!
Old 12-15-2008 | 09:39 PM
RC51Ryder's Avatar
Vroooom!!!
Dang, you guys have me scarred. I missed a gear once while merging/getting out of the way of a 18-wheeler but I think I just redlined it. She runs/idles normal and I've put 3,000 miles on it after that with no problems. Should I get a compression check just in case?
Old 12-15-2008 | 10:11 PM
akinin11's Avatar
thanks guys for all your responds i learned alot, today i pulled the plugs they seem fine no oil or anything so tomorrow i am taking it to the shop have them do a compression test and check for codes ,keeping my fingers crossed
ussi you think the type s valve springs will fit no problem isn't that from a 3.5 motor
Old 12-15-2008 | 11:00 PM
I hate cars's Avatar
The engine is hurt. Take it in, you're just prolonging the inevitable. It overreved, it now idles rough. Bent valves are the only thing that will do this.
NitroViper
03-20-2017 09:50 PM
Rob144
09-21-2015 08:18 AM
datadr
09-12-2015 09:12 PM
MyGuti
09-12-2015 06:52 PM
phillyguerrilla
09-11-2015 06:39 PM
Quick Reply: wrong gear questions
