is it worth it?!
is it worth it?!
So what exactly do dealers for A1 service??? Reason I ask is, I have an 06 TL with 38k miles and its due for a service. I called the dealer (Rallye Acura in NY) and they quoted me $590 for it, its insane! I asked what do they do and they said:
- oil change
- rotate tires
- check hoses
- check lights
What else do they do for $590??? Im so puzzled...
- oil change
- rotate tires
- check hoses
- check lights
Registered but harmless
Received 1,106 Likes
All you need is the A1-- which is $50-$80 at Acura dealers out here, and lower from independent shops.
However, Rallye may be quoting you some [completely unnecessary] 30K-mile service, including changing air & cabin filters, new plugs, valve adjustment, change of fluids for the brakes, transmission, steering, etc.
At least, I hope that is what Rallye would give you for that kind of service quote, none of which is called for under the A1.
I just told them do the oil change and probably an alignment since my car pulls a bit to the left and also a little shimmy on the steering wheel on various speed sometimes. I also told them to do an ATF change which is at $104, is that a good price? I know its a little high but I dont feel like crawling under the car, im not that confident to go under even tho I have jackstands and a hydraulic jack. Now how can I tell if they change the ATF oil, will I feel it shifting smoother?
DerrickW
11-15-2015 05:52 PM
