window deflectors
window deflectors
anyone has window deflectors on? if so, could you be kind enough to let me know where you got it, how do you like it, and if installation was easy...i was looking one at weathertech.com and wasnt sure if the deflector is dark enough...i have tinted windows (35%) so i didnt wanna get a clear one...the website said that they are lightly tinted but i didnt know how much that was....thanx for the help guys!!!
CTS-V Import Slayer
Installation is really easy and should not take more then 10 minutes to do the whole installation.
Quality of those Weatherflectors are tops and are composed of laminated layers.
Best regards
frenchew
CTS-V Import Slayer
The weathertech ones look a little different than the oems on the back...other than that they look identical. The backs on the OEMs extend the entire length of the door (both windows on back door) and taper to a point. Yours look like the just stop blunt right after the "roll down" window - not that it makes any difference. Just pointing this out to the original poster. Other than that....those look alot like OEM's. Yep...install on the OEM's took about 1/2 hour and they utilize clips and tape both, so you have to pull the rubber window channel out of the top part of the window on each door (real easy and doesnt hurt anything) so you can get the visors to seat correctly. Not sure if weathertech hook in the same way or not>?
They are really easy to install and the whole job took me 10 minutes.
Best regards
frenchnew
thanx guys for the help....i'll probably end up getting weathertech cause it sounds like it's easier to install....i hate installing stuff and am really bad at it also....anyway thanx for the help guys
CTS-V Import Slayer
Originally Posted by ivan308
A question on both of the units (OEM/Weathertech). How much do they actually stop rain/water from dripping into the car with the window open ?
Cant speak for weathertech....but if you open your window all the way with anything on your gonna get rain in! (j/k) Ok...seriously.....thats why I got em! Wanted to enjoy a smoke on the way to work and when it rained....it dripped in the window when I cracked it! Well...I can say that these solved my problem! No water inside now! Completely stops water from dripping inside...so long as you use them correctly. As I said...I dont think you can roll the window all the way down in the rain on any of these and not get a little something that spits in! But used correctly...and window opened an inch-two or so...you'll be good to go! It does also cut way down on wind noize & turb when you open all the way.
You can open then up a little more if stopped.
Best regards
frenchnew
xsilverhawkx
09-28-2015 06:51 PM
AcuraKidd
09-25-2015 11:18 PM
