Will 10w30 hurt
Will 10w30 hurt
I like to change the oil myself as I have heard many horror stories of oil changes being done even by the dealers and they did not cover the damage that they caused, like using the wrong filter or not even tightnening them all together. I like to use synthetic oils, and have just recently started to use Royal Purple, as all of the articles I have read, highly recommend this oil. My return question is, if I put in 10w-30, will this do any internal damage and must I use the 5w-20, and why?
10w-30 shouldn't "hurt" your engine. Honda wanted a way to get better gas mileage and also get by the "environmentalists" in emissions, so the recommended oil on our cars is 5w-20. 10w-30 is a thicker viscosity oil, and it would work in warmer climates rather than colder in our engines, IMHO. The thinner, 5w-20 oil works good in colder climates. Hope this helps!
10w30 will be fine...i dont know why you wouldnt want to use a 5w20 or 5w30, but 10w30 will work just fine...i wouldnt use anything heavier...as your car was designed with certain tolerances, and too heavy of a motor oil will put more load on the motor...
Originally Posted by RAMEX
All I have been using in my 07 TLS is 5w30 or 10w30 no problems here yet, I have a heavy foot so there is no way I would even try to use 5w20 no way!!!!!!
In the Florida climate I would suggest the 10-30. I run 30/10-30 year round in my TL because it only hits freezing once or twice a year and summers usually stay 100+ degrees. My 30wt in these hot summers is probably as thin as the 5-20 in a Canadian summer. Keep in mind, 10-30 can be used as low as 0deg F.
I was thinking about this the other day-
In a street-driven, average-to-moderate performance car, do I know anyone who has damaged an engine from using too light a weight, within reason?
No.
Do I know anyone who has damaged an engine from running too heavy an oil?
Yes. He broke the oil pump driveshaft running 30W in 35-ish degree weather. That was a small block with a high volume oil pump, but...
Just my personal experience.
I have no issue running 5W-20. I use synthetic for that extra measure of protection that it offers, mainly better cold flow.
Todd
No.
Todd
No.
Todd
No.
Todd
I wore the front cam bearing from using a high volume pump with a high relief spring in the Buick. Should I blame the thick oil or the fact that I knowingly modified the pump and considered the bearing wear a worthwhile tradeoff?
There is debate to the extra protection of thinner stuff. If you live in a moderate climate and the oil can flow decently at a 10W, do you really think there's anything to be gained by going to a 5 or 0? The other side of the argument is thick oil leaves a thicker film on bearings and that is what protects bearings before the pressure arrives. Of course a thicker film will protect better than a thin film.
Thanks for the input guys. This is my 3rd "Honda" vehicle and I have always used 10w30 oil in them, even though I have noticed the caps and books recommending 5w20 or 5w30.
This subject comes up almost as often as "which tire due you recommend".
Search feature is your friend. Use it and you'll get more confused than ever.
Acura took into account the various climates when they decided to put 5W-20 into the manual.
Why not use what the mfr. recommends? Do you really think we know more than Honda R&D?
I doubt that 10W-30 would hurt your engine, though, I just don't know why you would risk it.
Lots of opinions on the subject.
Acura took into account the various climates when they decided to put 5W-20 into the manual.Why not use what the mfr. recommends? Do you really think we know more than Honda R&D?
I ran 5w-20 in my 04 year around with no trouble while living in Central FL. The only trouble I had was sometimes finding it. However, now that I live in even hotter Key West, I will probably switch over to 5w-30 with no worries in my week-old 08 w/navi.
Some habits are hard to kill. All of my other vehicles always used 10w-30.
he’s right tho, if you beat on the motor then you should use 10w-30, I used 5w-30 in my TL I hauled ass everyday ended up doing an oil change to find engine shavings thankfully I caught it quick where I didn’t do DAMAGE to the motor just flushed it out and started using 10w-30 never had tha problem again with my other TL either after experiencing that
So you bump a 12 year old thread and then make a statement which is completely backwards; nice going. Long story short, there is nothing 10W-30 that 5W-30 cannot do better, or, said another way, 5W-30 is superior to 10W-30 in every metric you can choose. That said, 0W-30 is better than both.
Does the j32/35 shear oil badly? Not sure...surely not as bad as the f20/f22 of the s2000 for example, but shear resistance is an important metric that shouldn't be ignored when choosing an engine oil for your car.
Irrelevant.
Your statement is too generalized to be taken seriously. Not all oil manufacturers use the same base stock for each oil weight and not all oil weights are the same viscosity from different manufacturers.
To say all 10w30 oils share the same base stock is ignorant.
To say shear resistance is irrelevant is equally ignorant.
Keep replying, because everyone on here knows you have to have the last word in every thread you participate in.
For those truly interested in the facts, just do your own research. Bobistheoilguy.com is a good place to start.
I'll say it again for the cheap seats, a 0W-30 will out perform any 10W-30 of your choice. Period, full stop, then end.
Bob is a smart engineer who knows his subject matter well, but he is also a highly opinionated ranter who built a crude machine that tests how well an oil attempts to lessen the catastrophic damage of moving metal parts being forced into contact. His tests are not really applicable to engines running normally, because those kinds of tests are far more complex and time-consuming. I had to laugh when cheap parts-store generic oil scored far, far higher than Redline & Royal Purple. Ok Bob, how many drag racing teams use generic parts-store oil?
That said, use the grade of oil the manufacturer specifies = end of thread.
Ik this thread is over 5 years old but I’m getting ready to do an oil change on my 13 TL with 110k miles and I’m wondering should I use 0w-20 High mileage or would 0w-30 be better or even 0w-30 high mileage I drive the pretty damm hard sometimes long trips sometimes short anyone’s help is appreciated!
0-weight oils have a lot of viscosity modifiers to get them that thin and they can degrade with time. 0-weight is good if it get below zero regularly where you live.
If you have an SH-AWD model don't exceed 5k miles on a change and check oil religiously (like every time you get gas) since the 3.7L is prone to oil burning past the oil control rings.
13TL is a 4th gen but still a very similar engine. You can use 5W-20, or 5W-30 no problem. If it's cold where you live you may not want 10w-30.
