Why is my auto TL so slow?
#83
I am no where near as "hardcore" as most in these threads. My advice is forget the numbers, if it feels quick/fast and you enjoy it, stick with it and be happy. My TL-S is/feels plenty fast for me. I miss the low end TQ that my previous car had, but that was a turbo and the TL is a different animal. Aside from the difference is the powerband and AWD, the TL is an upgrade all around and still makes me want to drive it. I guess it helps that most of my driving is on the highway where the TL does its best work.
#84
Update: just got back from the drag strip. I took out my subwoofer in the trunk along with the spare tire. The best time I ran was 15.5 at around 75-80 degrees Fahrenheit. My three other runs were between 16.0-16.2 and I waited about 30 minutes to an hour between each run.
Here are the details of the best run:
60': 2.496
330: 6.805
1/8: 10.212
MPH: 72.86
1000: 13.113
1/4: 15.544
MPH: 93.11
I am starting to think it is my transmission not converting all the power: I did a top speed run the other day and at around 150 mph it seemed like the transmission had a "flare". It sounded like the engine was just revving up higher without giving the wheels any power. Needless to say that was the end of my top speed run, I slowed down and everything felt fine. There has been a 'whine' sound that I have been experiencing for awhile when I maintain a constant speed, it is most pronounced in 5th gear maintaining speed. Maybe a failing torque converter?
60': 2.496
330: 6.805
1/8: 10.212
MPH: 72.86
1000: 13.113
1/4: 15.544
MPH: 93.11
#86
All of the runs were in the sport shifting mode, I think the best time I shifted 2nd to 3rd at about 200 rpm before redline, others were shifted just at redline. I tried both power breaking and just flooring it. Wheels were not slipping in the runs, I had full traction
#87
Hey nice meeting you last night at the track. Sorry we didn't get the chance to run. 15.5 is not too shabby considering how hot and humid it was. My best time was 14.8 however my best time at this track this winter was 14.2 with the same mods I have now. 3.7 mani/tb, pnp runners, cai, IM thermal gasket, type s cats, rv6 jpipe, tb coolant delete. So in cooler conditions you car should run 14.9. Keep modding and swich your tranny fluid to redline and put in new trans switches is my advice.
#89
By the way, did you see that 1500 truck loose his rear axle due to wheel hop?
#90
power braking the TL trans for a better launch is bad. builds up a lot of heat. I hope you didn't do it too much.
Undying Dreams (07-09-2013)
#92
#95
#96
Nice meeting you too, we will have to meet up at a later race. I'm from Orlando but was visiting Sarasota for a few days so thought I would drop by the track. Ya I am going to keep modding, have a xlr8 v2 jpipe coming in and thinking about stock diameter lightweight pulley. Does the tranny fluid and switches help a lot? my trans in jerking when I let of the throttle a bit during 1st to 2nd and 2nd to 3rd gear shifts.
I sat in the stands and watched a bunch of races to scout what the other cars running. I saw a couple wrx's and speed3's running close to 16 and a new v8 M3 run 15.0 so don't feel too bad, poor guy really could not drive...
I ran a 07 wrx with a cobb tune, intake and exhaust. I had a crap launch and broke traction giving me a 2.6 60 foot time. I caught the wrx and beat him by a half car length and .2 on the 1/4.
#97
I just remembered one of my battery terminals has been corroded for awhile, I've always just cleaned off the corrosion but never knew how to stop it from coming back. I figured it was just the result of having an external subwoofer.
Would this hurt engine power delivery at all?
#99
takin care of Business in
read this thread:
https://acurazine.com/forums/3g-tl-problems-fixes-114/finally-fixed-problem-tl-being-sluggish-no-low-end-power-882439/#post14363313
I think the OP had the problem and IHC and him switched to die hard platinum battery and rest is all history....
I have not done this but the couple things I have done is:
TB Coolant Bypass
Full Ultimate cooling mod
Relocated IAT sensor
I am thinking of doing the shark mouth grille....
#100
you may want to hook a scanner up to see if you are reading 100% throttle (or close) at WOT. I was told at the dealer that the Accelerator pedal sensors are known to have problems on the TL because of heat from the exhaust. The TSX (i think) has the same exact sensor but no problems.
#101
depends on what you are reading....relative throttle will always be 20-30% even at idle....at WOT, it goes to 100%....whereas absolute throttle will be 0% at idle and will max out at 75% at WOT
#102
#104
Have the spark plugs ever been changed? You could also have either your precats or main cat slowly clogging up. Had that happen to my '02 Maxima, replacing the precats knocked the 45-85 time down by 3 full seconds.
#105
Also just changed air filter, cleaned battery corrosion, Added new jpipe. After this the car does feel faster, but there is still this hesitation almost like the car is bogging down in low rpm's when accelerating sometimes. It is noticeable now and then but I think something is bogging down the car. I am going to check the vacuum lines today.
MEKO (07-24-2013)
#110
The TRUTH About Why Your Honda Is Slow
I've owned several Hondas v6s. Sadly that's just how they get after 100k miles. They get really really REALLY slow. U can do some things to help for example..
change your cold air intake filter
clean/change out your EGR
Get new coils
do a "fuel system cleanup"
make sure your tires are good
Do a valve adjustment.
Out of all of those suggestions the most effective change you will probably see at over 100k miles is from the Valve adjustment and the new coils.
sadly these cars are just horribly slow after 100k miles and theres not much that can restore what ultimately comes down to drivetrain loss. Hondas 5 speed auto is very inefficient. After 100k miles the valve timing will go off pretty anytime u engage vtech
Hondas are very reliable in the sense that they will start and serve their purpose for many many miles.. they are NOT however fun to drive for very long.
WHY are Hondas still considered great cars to do many ppl if there's so many small annoying things that impact daily driving? Simple! Because they're made well enough that the every day drivers will not usually notice these things that lead to power loss, long 0-60 times, and the occasional weird noise coming from the hood. As long as it's getting them to work they're good cars "so to speak"
as an enthusiast I notice every small change in my car's performance.. lol and I've learned many lessons with the MANY MANY little things that's I've had to repair on the Hondas I've had.
bottom line is --> Hondas are pretty decent. If you want speed, problem free, visceral driving thrills for years to come get something different. Can you go wrong? Ohhh Yea. Most likely tho.. you'll have a pretty decent car that probably won't have ALOT of MAJOR Issues.
P.S. some of them do loom really cool
Get new coils
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
