Where to buy headlight reflectors?
Old Feb 25, 2016 | 01:35 PM
202009's Avatar
Ebay/black market/craigslist all come up short, I am trying to buy smoked or OEM headlight reflectors.
Is $100 USD really the going rate for something like this?
Old Feb 25, 2016 | 01:36 PM
You mean the ones inside the headlight? Or are you referring to sidemarkers...?
202009's Avatar
I tried to insert a pictures but it's not working:
http://klearz.com/lens/acura/04-08-a...ker-smoked.jpg
Old Feb 25, 2016 | 01:38 PM
Hit up JNC
Old Feb 25, 2016 | 01:42 PM
mvp2765's Avatar
$100 plus is the going rate
Old Feb 25, 2016 | 02:27 PM
GKinColo08TL's Avatar
Am I crazy but those aren't from the headlights? Tails, right?
Old Feb 25, 2016 | 02:31 PM
You're crazy gramps
Old Feb 25, 2016 | 02:33 PM
mvp2765's Avatar
nope, they're inside the headlights that curve around where the turn signal flashes. OEM ones are orange. Some people pop the OEM ones out and put in clear or smoked aftermarket reflectors.
Old Feb 25, 2016 | 02:34 PM
Guess I need to be more attentive...look more closely at pictures.
Old Feb 25, 2016 | 02:35 PM
You're crazy gramps
It's Mr. Gramps to you!
Old Mar 2, 2016 | 02:14 PM
Boosejars's Avatar
the only real places to get these are from Bruce - Acktl05/Endless, and Klearz.
those are the most reputable. in fact the guy from Klearz makes his to order, they are perfect fitment and require no modifying.
the other places are USR (uniquestyleracing.com) and Wisedetailz (sold also through Heeltoe)...but I wouldn't recommend either of those, USR require a great deal of modding to make fit in the headlight (trimming/sanding etc..), and I won't get into details on the Wisedetailz (shady work)...
but yeah, reach out to Bruce, or Klearz. I ordered mine from klearz and did a smoked diffuser. You can expect to pay $100 or more - but is a quality piece.
last option is to find someone selling type s diffusers - they are clear in the front, and amber near the ends, and you can simply tint or wrap the ends to eliminate the amber piece...
good luck sir...
Old Mar 2, 2016 | 02:18 PM
Boosejars's Avatar
Here are the ones i got smoked
installed into the housing and added CF wrap to the ends
final product
Old Mar 18, 2016 | 10:31 PM
SurfingScotty's Avatar
2007 6SMT Type-S
final product
Looks good! How did you get them smoked? Also, where did you buy the carbon fiber wrap? Would you use the CF again if you had to do it over again or would you use something else?
I've got my pass headlight out to replace the ballast and I wanna delete the amber in my S headlights while it's out. I'd like to buy the clears but I can't be w/o my car for 10 days.
Old Mar 19, 2016 | 06:04 PM
tlbase04's Avatar
The Acura Noob
Was looking at the how to black your headlights out and now found this. Think im going to add both to my mod list. Great work!
Old Mar 19, 2016 | 06:56 PM
Boosejars's Avatar
I ordered them smoked from Klearz he sells a light smoked 5% and medium smoke which is the standard smoke like the ones I have he is based in Canada so it will take some time, i think in all it was just under 3 weeks from order placement to being at my house, but perfect fitment- 2004-2008 Acura TL Clear Headlight Markers
I bought Di-noc CF wrap from amazon - went on fairly easily, haven't had any issues and haven't gotten any fading from the wrap and it has almost been a year since doing the headlights, to answer your question, yes, i would add the wrap again, just makes it stand out more...
http://www.amazon.com/Black-3M-DI-NOC-Carbon-CA-421/dp/B0062A7M2G/ref=sr_1_2?s=automotive&ie=UTF8&qid=1458431545&sr=1-2&keywords=black+3m+di-noc+carbon+fiber+dinoc+flex+wrap+ca-421 http://www.amazon.com/Black-3M-DI-NOC-Carbon-CA-421/dp/B0062A7M2G/ref=sr_1_2?s=automotive&ie=UTF8&qid=1458431545&sr=1-2&keywords=black+3m+di-noc+carbon+fiber+dinoc+flex+wrap+ca-421
Good luck on your lights...you can always reach out to Bruce/Acktl05 about doing the trade ins - you tell him what you want, he ships you the modded set, and once you receive the modded set you send him your oem lights, that way there is no down time...
Another guy to check out - Arora Customs, they can assist too - great guys as well. Arora Customs
Happy Modding...
Old Mar 20, 2016 | 09:59 AM
2007 6SMT Type-S
Amazon.com: Black 3M DI-NOC Carbon Fiber DINOC Flex Wrap CA-421 24"x12": Automotive
Happy Modding...
Thanks for the reply. Good info. I wish I had planned this project but I didn't. I took the day yesterday to pull my headlight to replace a bad ballast. While I had it out, I noticed a lot of dust and a couple of dead insects Inside the housing (found out the previous owner had removed the seals on the back). One thing led to another and I was tearing my headlights apart.
I ended up "smoking" the amber reflectors with some Testors Black Transparent spray paint. I used some of this stuff (red) on my bike's rear turn signals which covered up the Amber better than the black paint did. You can still see a hint of amber in the light but it's not as offensive as stock and it's still functional. I removed the reflectors on my 1st gen TL when I retrofitted it with E55 HID projectors (that was a 2 week project) (shown in my avatar). However, In order to pass inspection each year, I'd have to glue on some orange reflectors to the outside of the assembly.
Anyway, I think it turned out pretty good for an impromptu day project.
**A couple points worth mentioning** DO NOT try to clean the reflectors or any of the chrome inside the housings! The chrome finish will start to rub off! There is a chrome painted horizontal bar that's in the middle of the diffuser. The finish rubs off extremely easy. Underneath the finish exposes a clear plastic tube. Doesn't look very attractive so I ended up painting that too.
Also, as someone else mentioned, using a soldering gun to melt the plastic tabs on the reflector worked very good. But you still need to be careful as it's more delicate than the feelings of today's "Generstion Y".
<a href="http://s1083.photobucket.com/user/Scott_Buzard/media/Mobile%20Uploads/image_zpsdan96cup.jpg.html" target="_blank"><img src="http://i1083.photobucket.com/albums/j400/Scott_Buzard/Mobile%20Uploads/image_zpsdan96cup.jpg" border="0" alt=" photo image_zpsdan96cup.jpg"/></a>
Old Mar 20, 2016 | 10:03 AM
2007 6SMT Type-S
Close up
<a href="http://s1083.photobucket.com/user/Scott_Buzard/media/Mobile%20Uploads/image_zpsnp1vufq8.jpg.html" target="_blank"><img src="http://i1083.photobucket.com/albums/j400/Scott_Buzard/Mobile%20Uploads/image_zpsnp1vufq8.jpg" border="0" alt=" photo image_zpsnp1vufq8.jpg"/></a>
Old Mar 20, 2016 | 08:17 PM
Boosejars's Avatar
Nice work! post some pics once you get them installed back on the car!
Old Mar 23, 2016 | 09:08 PM
2007 6SMT Type-S
Thank you! Here they are:
<a href="http://s1083.photobucket.com/user/Scott_Buzard/media/IMG_11181_zps0q2gljc1.jpg.html" target="_blank"><img src="http://i1083.photobucket.com/albums/j400/Scott_Buzard/IMG_11181_zps0q2gljc1.jpg" border="0" alt=" photo IMG_11181_zps0q2gljc1.jpg"/></a>
<a href="http://s1083.photobucket.com/user/Scott_Buzard/media/IMG_11191_zpsjfujxlcf.jpg.html" target="_blank"><img src="http://i1083.photobucket.com/albums/j400/Scott_Buzard/IMG_11191_zpsjfujxlcf.jpg" border="0" alt=" photo IMG_11191_zpsjfujxlcf.jpg"/></a>
<a href="http://s1083.photobucket.com/user/Scott_Buzard/media/IMG_11221_zpsa8kagbkb.jpg.html" target="_blank"><img src="http://i1083.photobucket.com/albums/j400/Scott_Buzard/IMG_11221_zpsa8kagbkb.jpg" border="0" alt=" photo IMG_11221_zpsa8kagbkb.jpg"/></a>
Old Mar 24, 2016 | 06:04 AM
Boosejars's Avatar
Looks good dood, already rocking the switchbacks too!
Old Mar 25, 2016 | 07:42 AM
2007 6SMT Type-S
Yes sir, and thank you! Got them when they 1st came out. Had to send back one bulb & control unit after about 1 year of use. Their return process was simple. Gotta love the lifetime guarantee.
JJones91
Oct 17, 2016 06:52 PM
bentleyvtech
Mar 20, 2016 08:23 AM
M-EaZii
Feb 18, 2016 09:59 PM
