Where to buy the AC compressors components ?
Old Jun 12, 2017 | 11:30 PM
Le7316's Avatar
Does anyone here ever replace your AC clutch/pulley/coil ? I'm not talking about the whole compressors . Just those 3 parts. If so , which one did you buy ?
Thanks !!!
Old Jun 13, 2017 | 05:56 AM
nfnsquared's Avatar
https://acurazine.com/forums/3g-tl-p...-guide-772614/
Old Jun 13, 2017 | 07:11 AM
Turbonut's Avatar
From the prices I see, probably less expensive just to get a new compressor.
The factory parts, discount, $286.
Advance Auto $350.
Old Jun 13, 2017 | 12:26 PM
guitarplayer16's Avatar
I am also wondering about this too.
My AC recently doesn't work and I think my compressor pulley is making a knocking sound. I'd like to avoid having to recharge the AC system and all that.
It is without a doubt a cheaper method to buy the whole compressor with the clutch attached. I'm confident to change out the clutch system, but I don't feel confident at all dealing with refrigerant and such.
Old Jun 13, 2017 | 12:50 PM
Le7316's Avatar
I just got a used Type S one from our members here.....but yeah I will just use the clutch assemblies and keep the compressor. What really fail is the coil behind the pulley.
Now question , I went thru this thread earlier and the op has mentioned to make sure the gap btwn the clutch and the pressue plate is 0.3 - 0.55mm .....not sure what he means by this ,
" pressure plate and pulley. the acura defined spec is 0.3mm - 0.55mm"
Does this mean if I can turn the pulley freely w/o touching anything then we call its good ?
Old Jun 13, 2017 | 01:14 PM
Le7316's Avatar
this ?
