When using the heater...
Old Dec 21, 2006 | 02:57 AM
abhi101cru's Avatar
06 TL
Hey guys, I just had a quick question about using the heater on your Acura TLs.
Do you guys just hit the auto button/increase fan button and set your temperatures to heat your car. As in, do you leave the a/c on or do you turn it off when you want to heat.
I always hit the a/c button to turn it off when I was heating but I noticed that this really caused bad smells. So, I'm just wondering whether all of you leave the a/c on when heating or whether you turn it off.
Old Dec 21, 2006 | 03:48 AM
whatjones911's Avatar
I turn off the a/c when i use the heater most of the time because it is acutally hot with the a/c off. On full AUTO mode, meaning the a/c is still on, the air would only be a little bit warm even at 78 degrees. The problem with having the a/c off is that the windows begin to fog up.
Old Dec 21, 2006 | 04:40 AM
GoHawks's Avatar
2012 Cadillac CTS-V Coupe
The A/C isn't just for cooling. It dehumidifies. If I recall correctly I remember reading in the manual for my old '01 TL where it stated that the compressor will cycle off/on until the temp goes below freezing. My guess is that once the temp goes below freezing you actually want humidity back in the air (that's why we have humidifiers in our homes turned on during the winter).
I would imagine the current gen TL is the same. I would just leave it at FULL AUTO.
Old Dec 21, 2006 | 05:58 AM
bhelsdon's Avatar
full auto and 74 degrees all year round for me. I find the system works perfect, I only wish the mirror heaters came on with the rear defrost.
Old Dec 21, 2006 | 01:25 PM
Will Y.'s Avatar
Registered but harmless
I hit "auto," set temp and turn the A/C off. See https://acurazine.com/forums/showthread.php?t=149913 .
Old Dec 21, 2006 | 04:37 PM
SouthernBoy's Avatar
Registered Member
I use the manual mode most of the time, year 'round. When I do chose to use the A/C, I use the auto mode.
Old Dec 21, 2006 | 05:17 PM
csmeance's Avatar
put on 80 auto for 5 minutes then put it to 74 for the rest on auto.
Old Dec 24, 2006 | 01:55 AM
sunny201's Avatar
A J35A8 EG civic is in
Is it me or do the TL's (or at least the 07s) have a sun sensor? When Im driving and am facing towards the sun it starts blowing out cooler air. Then when I turn and face a different directions, it goes back to the hot air.
Old Dec 24, 2006 | 07:33 AM
neuronbob's Avatar
All navi TLs since 2004 model have had a sun sensor to do exactly as you are saying. Great feature!
When I had my TL, I left it on 72 degrees, full auto, all the time. What I noticed was that it didn't blow as much air until the engine was heated up--a definite plus during the winter as no cold air blows on you. Another great feature that my RL shares!
5000 posts! woohoo!
Old Dec 24, 2006 | 07:58 AM
GoHawks's Avatar
5000 posts! woohoo!
Actually I believe TLs since '99 have the sun sensor. My '01 would start to blow harder once the sun came shining through the windshield. The '04 TLs (w/Nav) and now also the RL have the feature where it will adjust vent temp (i.e. driver & passenger) based on where the sun is located.
Old Dec 24, 2006 | 09:17 AM
neuronbob's Avatar
Ah yes, I stand corrected. My 2G TL (2002) was far enough in the past that I have trouble remembering some of the details.
briny319
Jun 22, 2018 06:32 PM
CL-S progression 01
May 24, 2012 12:21 AM
saersxlr8
Jan 28, 2009 12:37 PM
2002TLSNavi
Feb 5, 2003 07:53 PM
