When do you change your oil 5k or the % meter
Do you guys do it at 5k with synthetic oil or do you wait till the % meter on the trip computer says it's time.
TripAcez (06-07-2011)
I usually change my oil around 50%-40% on the MID.
3G TL/2G MDX Owner
go by the MID. and yes there are many other threads on the issue...
if you change your oil more often say the traditional 3K or 3 months, you're throwing money away.
i usually only get about 4K miles per change based on my MID (change when i hit <15% or <10%), when i can get it done. others with lots of hwy driving can get over 7-8K miles per change. some will change every 5K regardless of MID status. i believe most of us go by the MID, as will the dealer and acura (its in the owner's manual).
Unless your motor is modded there is no reason NOT to follow the MID. Acura's Maintenance Minder system for the most part is pretty conservative and the TL's system was based around regular oil not synthetic.
I know people are going to say that oil is cheap but a motor is expensive, but motors are becoming more efficient and oils are getting better so there is no reason not to trust the engineers at Acura/Honda.
Use a good quality oil (Synthetic if you want, I know you folks down in the US get good deals even on brand name synthetic oils) and follow the MID (save the environment and save some $$$). This is what I've been doing for the RDX and the internals are spotless and problem free with 80k on it now.
AZ Community Team
Received 7,771 Likes
By the MID I change my oil about every 4500 miles.
Works for me.
Works for me.
well you are giving your motor mor wear. the mid follows what the sensor sense in the oil. it isnt based on mileage for TL's with maintanance reminders which has sensors that sample the oil. you running your car vwith shitty oil for 4k miles is doing more harm than good.
If the MID had taken account of me using Synthetic oils. Then I would follow it.
AZ Community Team
The MID is based on a variety of factors including time, mileage, rpms, temperature, etc. Those factors a used in some sort of algorithm to predict or estimate oil life.
If your driving habits are pretty stable, the best thing to do is send used oil to a place like Blackstone Labs for an evaluation. Over the course of a few samples you can hone in on the ideal mileage for the way you drive the car and the oil you use.
If you're going 8K with a synthetic fine, but not on regular oil. And as BearCat has stated there is no sensor for the vehicle to sample the oil but it does exactly what BearCat has stated to factor in the optimized oil life
Used oil analysis for extended oil change intervals
At this point, I am more concerned about the oil filter (Purolator PureOne) and how long it can last. What they tell me is that the fact of low solubles found in my used oil (0.5%) it would not be a problem to go to 10K miles.
My question to the tribologists here is can car oil filters last that long?
Thanks in advance for sharing your insights and experience.
I go about 500-1000 miles past 0% on the MID to account for the full synthetic I use. I don't beat on the engine, so I get about 6,000 miles on the MID-calculated life.
Excellent suggestion and a coincidence since I just got my 3rd used oil analysis report from Blackstone Labs. My car had 98,731 miles on it and this recent report had 8,138 miles on the oil and their comment was the oil had more useful life and suggested I go to 10K miles.
For the people who are changing their oil less often than what the MID suggests, do you reset the MID when the reminder flashes? Or do you wait to reset it until you actually change the oil?
recently my screen said i was 2399 miles past service due
i was running on mobile 1 ep with a mobil 1 filter for 7500 miles that time. going for 10,000 this time around
AZ Community Team
.... this recent report had 8,138 miles on the oil ....
If your filter were insufficient, this would be reflected in the oil.
Can you post your Blackstone analysis please? What oil were you running?
i do 3000-3500 miles every change with conventional oil. engines are expensive and i dont care about $20 here or there cause i change my own oil. Also after every oil change I feel a nice amount of personal gratification. I just enjoy putting money into my car in a positive way. Although I will be moving to Mobile 1 here soon, just havent made the move yet, but im sold on it. As for MID i just reset mine when it hits 0%. I keep a personal record in my garage as to oil milages for both my cars
7th Gear
Hello all
I am relatively new and this may be answered in one of the other threads for oil changes but what I am understanding after reading all the posts is...........my TL does not know if I have synthetic or normal oil. It starts count km after a service and there is a predetermined formula that will judge oil life. Such as lots of low speed (city) driving and the car will tell me to change around 4000 km, lots of high speed (highway) driving and it will tell me to change around 6000 km. Or similar numbers.
If that is true then it sound like a dumb system to me. Am I wrong?? Like i said in the beginning I am new so do not crucify me, but it sound like a dumb system if there is no sensor.
Thank to all
Thank to all
AZ Community Team
Few (VERY few, if any at all) cars have an actual sensor. Almost every car on the road with an Oil Life Indicator is based on an algorithm of environmental factors and driving habits.
It's probably pretty hard to do a UOA "on the fly".
Acura assumes you'll use conventional oil. In the Owners Manual it says (paraphrasing), "You can use synthetic oil, but you still have to follow the MID for warranty purposes."
Hello all
Thank to all
Thank to all
Since oil is cheap I say just follow the MID. I love changing my oil!
I can't make it any easier, every 5,000 miles with synthetic at the dealer plus a tire rotation. Air filter every 15,000 miles & Trans fluid every 20,000. 5,000 mile intervals is alot easier to calculate then 7,000/8,000 miles.
the overexplainer
eh..i just wait for specials on the "full synethetic" valvoline/pennzoil specials. Yes i know they're not "real" synthetic but for 30 bucks including the filter...yea.
mada51589
05-03-2022 08:54 PM
