Whats Next?
Whats Next?
I have a 04 tl auto. I dont have much money, but i try to find the cheaper mods for my car. I have an injen intake, I removed my mid muffler and replacing the stock resonator with a dyno one. I have some fog lights on the way as well as leds for the sidemarkers. Anyone have a good affordable mod to do next?
I will play. Hopefully this does not turn out like other newbie threads.
First you need to figure out your budget
2nd you need to figure out you want performance (handling/power) or looks since you said you have a small budget for mods.
3rd wheels/tires and springs (budget friendly) are probably the most noticeable exterior modification you can do to a car.
4th if you want power, and if 04 TL is anything like CL, then header + high flow cat + your injen intake will be good enough for now.
you can go to black market section and get some used ones for cheap. and they are steel tubes.. so most likely there shouldn't be any problem with used ones.
but installation will run you around another $150ish. and since your TL is almost 10 years old, it is a good idea to get some new shocks while you are at it to save on installation cost.
you will feel the difference right away.
i'd recommend some coilovers but i think it might be a over kill for your needs and good ones are not cheap.
i accidentally posted this somewhere else and this is one of my replies
was also thinking of replacing the door lights (the ones that light up the floor) and putting blue leds? what were you thinking?
LED Interior is always a nice cheap mod.
Power wise, the jpipe or pre cat deletes should be next on your list
Also check out this page: https://acurazine.com/forums/perform...owners-701772/
Weight removal:
https://acurazine.com/forums/perform...st-1-a-610974/
And suspension.
The 3G TL doesn't have headers. They are cast into the heads. High flow pre-cats or deleting them is our version of headers.
And suspension.
