08 TL - 47K. no major repairs.
My only concern is I'm starting to get A LOT of rattles here and there. It's pretty annoying that a luxury car would have so many little rattles. |
damn and here I was thinking i had pretty much the highest mileage 3G LOL...am at 162,000...
165k on an 04 base here
Originally Posted by vp55
(Post 13985798)
^Not bad at all. What oil and weight have you been using since you had it?
Originally Posted by HondaFan81
(Post 13985924)
I would add to jhumbo's repair history that the extra labor cost of timing belt tensioner (132K) would have been negligible at the later repair date if it was properly inspected/replaced at the timing belt/water pump repair date (107K).
I've had my 2004 Base Auto since it had 79k, and she's at 176k now. Things I've done: Regular oil changes, brake pads, one set of rotors, all motor mounts, one front sway bar link broke, timing belt (and related other parts) at 125k, and one rebuilt transmission (went out at 160k). Before the transmission rebuild, I had done the 3x3 done about every 30k miles or so. I drive very hard, all the time, and I'm very impressed with the motor. Still runs pretty damn close to the way it did when I bought it! Truthfully, I can't believe the poor transmission made it to 160k the way I drive. All in all, I'm happy with my purchase. I've read every thread about every problem and I guess I just got real lucky with this car.
just hit 161k....bought it with 42k a little over 3 1/2 yrs ago. still runs awesome. 100 out of my 106 mile commute is highway. I've only had to do regular maintenance, battery, T belt, Brakes (@ 130k), and a couple of sets of tires.
Now how many of you with over 100K have had no tranny issues?
Originally Posted by bahasad
(Post 13987074)
Originally Posted by ep3kid914
(Post 13987130)
right here original tranny on 165k right now just the case has a crack so i usually check fluid every week
Originally Posted by swoosh
(Post 13987134)
how did the tranny case get that crack? hit somewhere?
damn....hope everything gets worked out well man....
(Post 13987165)
^^^ :nod:
it does seem pretty decent....keep us updated on how it goes :thumbsup: |
Just turned 85,000 miles on my 07' TLS, to date dealer has replaced driver seat track, the CD player and just last week the oil pump seal & CV boot, all under warranty.
newbie just bought an 04 TL with 55K 6spdMT.
just bought an 06 w/ Navi 6MT and just turned 76k. Got it serviced and just found out its got a new transmission that barely had any fluid in it.
According to the car fax it looked serviced pretty good, but should of brought it in to a mechanic first. Hoping it keeps chugging for at least another 75k! My goal is to get at least 150k on the odometer. |
(Post 13987074)
'08 TL-S w/ 32,300 miles ~ runs purrfect
05 with 190k, original trans.
My 04 5AT is at 267k and climbing!!
I've had the timing belt and tensioner done, new radiator, Ac compressor, and other than that just basic oil changes/maintenance. http://i43.photobucket.com/albums/e3...EA90404A2D.jpg |
:woot:
267K !!! awesome !!! |
267... =D makes me feel a competitive need to see my 07 TL-S there... 140k to go!
Originally Posted by Legitka9
(Post 13995976)
I've had the timing belt and tensioner done, new radiator, Ac compressor, and other than that just basic oil changes/maintenance. |
My 08 is just over 122K. 50K miles in 15 months of ownership. :thumbsup:
Originally Posted by jhumbo
(Post 13996325)
267k and it's a 5AT. Awesome!! Do you know if it is the original trans? How many miles were on the car when you got it?
(Post 13997355)
I bought the car brand new and it has the original engine and transmission, when I bought the car it had 12 miles on it. I've changed the transmission fluid every 30,000 miles and oil every 5000 miles. It has been a very good car to me. Only problem I'm having is with my drivers side headlight, the high beam does not work.
Originally Posted by 3gstealth
(Post 13997365)
This is very encouraging! What transmission fluid have you been using? Have you ever changed the pressure switches?
As far as the engine oil, I'm using a premium conventional Mobil 5000 with Mobil 1 oil filter. The car still to this day burns no oil, leaks nothing and is mechanically sound! |
wow...this just made my day!
i just hope mine makes another 25K on original trans before i get rid of it! |
[QUOTE=Legitka9;13995976]My 04 5AT is at 267k and climbing!!
I've had the timing belt and tensioner done, new radiator, Ac compressor, and other than that just basic oil changes/maintenance. 04 5AT 267k official! :workout: |
08 has 53k miles :).
2005 TL with 44K miles.
Just picked up my Type S
2007 with 22,090 |
Just hit 41k on 07 TLs.
(Post 13997355)
Well done, dude!!! :thumbsup: |
Bought my 04 TL with 89k on the odometer in 04/2011, currently have 115k and hoping to get to over 200k!
134xxx bent valves and blow by.. :)
Compression 225-200-185-150-140-130 |
^^^ happened recently? or this is when you did the build or some like that?
(Post 13996325)
(Post 13997355)
(Post 13997451)
I've been doing the 3x drain and fill with ATF Z1 up until 210,000 miles and since then I've been using the new DW-1 fluid. I have never replaced the pressure switches, I'm thinking that with my frequent transmission maintenance it's still working fine.
Here's a few shots of my high mileage UA6
Man do I love this car!!!!!! http://i43.photobucket.com/albums/e3...66A79B2147.jpg http://i43.photobucket.com/albums/e3...6775F2D8B0.jpg http://i43.photobucket.com/albums/e3...66B51282E4.jpg http://i43.photobucket.com/albums/e3...66B077E7D9.jpg |
07 TL with 63k
