What is this high pitched sound
Old Mar 18, 2024 | 01:48 PM
ballen5150's Avatar
2007 TL 105,000 miles
Newish high pitched sound from near serpentine belt. Im due for a timing belt/water pump job soon and looking for a shop in Boston area.
Any ideas?
How does rest of engine bay sound?
Old Mar 18, 2024 | 02:28 PM
If you remove the PS pump belt you will eliminate the belt tensioner, A/C compressor, PS pump & alternator.
If the noise continues without the PS pump belt then something is amiss with the TB components.
If the noise is gone with the belt removed, then something is amiss with one or more of the components in the first sentence.
Old Mar 20, 2024 | 02:06 PM
nanxun's Avatar
Had a similar problem about 2 weeks ago on my 2007 TL with 106,800 miles on the clock.
After a thorough inspection, had the drive belt tensioner replaced which seems to have done the trick.
Timing belt and PS pump are next on my list, although both were replaced (by previous owner) at 51,700 miles in July 2015. Then again, water pump, drive belts and tensioner were also replaced at that time, too.
Old Mar 22, 2024 | 12:53 PM
ballen5150's Avatar
Even though I had the plastic engine covers on I think some coolant may have got on the belt when I topped it off a couple of weeks ago. Took a wet rag and poured a little water on the belt and noise stopped. Hopefully that was it
croman580
Jul 7, 2023 08:41 PM
pjosh
Sep 15, 2011 10:23 AM
svgwpb
Feb 1, 2011 11:58 AM
fred3113
Jan 6, 2004 09:59 AM
