What does your car idle?
Old Jan 7, 2004 | 10:37 AM
datplayaz's Avatar
Post What does your car idle?
I was wondering what everybody's car idle at? cause mine is idleling around 1500 rpm when it's in park, I live in Utah and it's winter time and all, so I know the cold weather has something to do with it, but should it still idle like that even after I drove around for a while and my engine is warm?
Old Jan 7, 2004 | 10:39 AM
VTEC=happiness's Avatar
What's a TL?
sounds way high...mine is about 750 when resting
Old Jan 7, 2004 | 10:48 AM
that is way high. Yes, it should be around 750. I suggest you bring it to service and have it checked.
Old Jan 7, 2004 | 12:04 PM
waymay1305's Avatar
Is that 750 while the vehicle is in park or is that 750 with your foot on the brake?
Old Jan 7, 2004 | 12:09 PM
It's probably an easy fix but no new acura should idle at 1,500rpm when it's resting.
Old Jan 7, 2004 | 12:45 PM
Bitium's Avatar
Retired MOD
Re: What does your car idle?
Yes this is normal......Only in the winter and when you first turn the car on. After a few minutes in should idle at 650. You would understand this if you had an old car.....for example I have a 91 primera and when I turn it on in the cold 40f or less and I don't press the gas pedal, the car sounds like is going to die. All I have to do is give it a little gas pass 1.5k rpms for a few seconds for this to go away.
That I know this is normal on all model TL's from 99 to 04
Old Jan 7, 2004 | 01:53 PM
Yaaro Dhana's Avatar
We have had single-digit nights around here over the past couple of days. When I start the car, it idles a touch above 1000rpm. It drops back to around 700 or so once it warms up. I haven't noticed it idling at 1500rpm at these temperatures.
Old Jan 7, 2004 | 02:01 PM
What's a TL?
Re: Re: What does your car idle?
It is not normal...I think you misread the question....it asks if it is normal even after driving it a bit.
Old Jan 7, 2004 | 02:56 PM
rets's Avatar
Moderator Alumnus
RPM could still be high unless you have some reasonable driving distance against your cold temperature.
I guess not many ppl will shift to PARK and see how high your RPM will be when the engine temp gauge is still down to the bottom.
I know my RPM will be high above 1k if my engine temp is still cold as well as my tranny is in PARK. However, after driving 1 or 2 miles, the idle RPM should drop to 650-800.
Old Jan 7, 2004 | 03:29 PM
Bitium's Avatar
Retired MOD
Re: Re: Re: What does your car idle?
I did missread the question. UNLESS your guage is at normal possition somewhere in the middle, then is kind of normal, thought not expected. If it is at that point and still idles that high then you have a problem, you just need to adjust it....very simple on my TL, don't know about 04.
Old Jan 7, 2004 | 06:08 PM
same here
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
Mike Bertram
Sep 10, 2015 09:27 AM
NSolace
Sep 3, 2015 08:14 PM
Papa Roe
4G TL Problems & Fixes
Sep 1, 2015 09:41 PM
