what do u remove??
Old Oct 30, 2010 | 01:40 PM
24no7's Avatar
UA6 SSM TL
what do u remove??
what did u guys remove (for those who blacked/cleared their headlights)?? obviously u guys removed the front bumper in order to take out the headlights but thats not my question. I would like to know if u guys removed something from the headlights like bulbs, etc. I've been planning to do mine very soon, and i wanna install the led angel kit. does anybody know where i can get the kit for the tl 04?? i have the type-s head lights but i don't wanna have 4 rings, instead i wish to have only 2 that's why i was thinking on getting the kit for the 04 plus it's a little be cheaper.
Something like this:
Old Oct 30, 2010 | 01:58 PM
Type One's Avatar
Dont get new headlights. Stick with the Type S ones and just put one ring on each side.
Old Oct 30, 2010 | 02:39 PM
ionojimbo's Avatar
im pretty sure you can just buy the 2 rings and still putit on your type-s lights
Old Oct 30, 2010 | 02:43 PM
wahshi's Avatar
My TL loves summer
For the ppl who cleared their headlights they took out the amber diffuser. For the blacked out look I believe they took out the diffuser and sprayed the housing black. You should be able to find a kit on ebay.
Old Oct 30, 2010 | 03:12 PM
24no7's Avatar
UA6 SSM TL
i don't wanna black them out, i wanna open them to install the angel kit. is there anything that i have to remove before putting the headlights in the oven?? also to seal them back i assume i will have to do the same process, i mean putting them in the oven so that i will be able to re-use the glue. correct me if im wrong thanks
Old Oct 30, 2010 | 05:58 PM
wahshi's Avatar
My TL loves summer
Check these out...
https://acurazine.com/forums/3g-tl-2004-2008-93/diy-blacked-cleared-headlights-3g-garage-g046-589746/
https://acurazine.com/forums/2g-tl-problems-fixes-117/clearing-headlights-long-write-up-592215/
Old Oct 30, 2010 | 06:59 PM
DeathMetal's Avatar
Fearless DIY Guy
Fuck me, OP, your post is a trainwreck. I'd like to help, but I don't know wtf you're asking.
Old Oct 30, 2010 | 07:15 PM
o4Komodo's Avatar
Rev High; Drive Happy
You can buy any angel-eye kit there is. You don't have to use all 4 rings. If you find that the o4-o6 angel eye kit is cheaper then you might as well get that since you only plan to use 2.
As for removing anything to install angel eyes only... you do not need to do anything.
You can bake the headlight in the oven as is. Once you pry the headlight apart you're going to have to dismantle it. You'll need to find a way to 'glue' the angel-eye to the shroud as well. You will then need to drill 2 small holes to feed the wire through.
Before putting the headlights back in the oven find yourself some sealant... like silicone or Nissan Butyl Rubber. Try to put it back as flush as you can before baking it.
Once baked, take it out of the oven as quick as you can without burning yourself... then use a series of clamps to ensure you can get as tight of a seal as possible.
If you find any gaps that may cause condensation use some silicone to cover up the gap...
It's the best way I can explain it.
Old Oct 30, 2010 | 11:01 PM
24no7's Avatar
UA6 SSM TL
thanks o4komodo
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
dainmezron
Oct 16, 2015 06:56 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
lowgrowl
Sep 26, 2015 05:18 PM
