wet funny smell ??
wet funny smell ??
sometimes when i get into the car there is this wet funny smell that comes and goes each time i get in thte car. I can smell it when driveing but still i can't not ping point the smell but my girlfriend saids it coming from the vents but i dont think that true. Any one having this problem??
thanks
thanks
Originally Posted by NFLblitze1
does it smell like milldew?
Check your back seats. Some people had a problem with water collecting under the seat and soaking up into the foam. I don't remember exactly where the water was coming in from though. If that's your problem then just do a search to find out the fix/cause.
I had the same exact problem, it was comming from the vents even though they were not on. If you don't have the recycle feature "ON", air will still pass through. I found this to be a problem typically if I used the A/C the day before. If you are using the A/C I suggest you turn it off approximatley 3-5 minutes before you arrive to your destination. Make sure you leave the fan on and the A/C off, this way the fan will dry out your cooling coils...thus no wet funny smell.
I have the same problem. I've noticed that it's very noticable on hot days when I first get in the car and am trying to get the car cooled off. The smell is very strong.
I'll need to try phillyboi's suggestion. Could it be the filter?
Your dealer will also have a disenfectant / deodorizer that they can use.
First check to see if the condensor drain is clogged. Run AC for a while, when you stop, get out and make sure you're dripping, if not, the condensor drain is plugged. You'll definitely want the dealer to clear it out and then clean it.
I had the same problem up until about May/June. then it seemed to go away.
Now it has returned.
I think it is correlated to how I am using my A/C during the hotter months.
In the cooler months, I only use the A/C about 50% of the time, and the smell has returned!
Originally Posted by trancemission
I read that title and was like....hmmm.....I wonder.....
But I think Phillyboi and Southern are exactly right. My CL did the same thing...
The BMW 5 series (E39) had the same issue as the TL, but came out with a TSB to add an extra drain to ensure moisture does not build up, and a spot to spray disinfectant in.
Sarlacc
Console & Computer Gaming
Sep 30, 2015 02:15 PM
