VSA On or Off?
Old Dec 28, 2008 | 07:54 AM
golfjwr's Avatar
Soon I will have
VSA On or Off?
What have you noticed when driving with the VSA on vs. off? Spinning the tires is a lot easier
Old Dec 28, 2008 | 08:19 AM
SouthernBoy's Avatar
Registered Member
Yes breaking traction is more of a problem (as in easier) with the VSA off. If you are of a mind to race the car (drag racing, that is), you want to turn off VSA and use whatever skills you have to run the car. Hiowever under normal everday driving, you should keep your VSA on at all times. This is a wonderful feature that can help you in the event conditions warrant its use. If can help keep you out of an accident and/or keep your car from being suddenly redesigned.
Old Dec 28, 2008 | 08:58 AM
nyczballa's Avatar
Yes I agree with Southernboy and also to mention for the people that live in areas where is snows such as the North East VSA can be good both on and off depending on the condition. Its good to turn it off when driving up a hill because you can put more power and burn through the snow. Its also good to leave it on while driving on a straight road in the snow because it helps keep the car from losing control without trying to hard.
Old Dec 28, 2008 | 09:08 AM
bimmerman's Avatar
Traveling the country
I guess it depends on your location. It is mostly warm here so I have it off more than on, but i also have a 6 spd. If it is raining or the weather is bad I will leave it on.
Old Dec 28, 2008 | 09:12 AM
Registered Member
Yep, you're right on both counts there. If you are about to get, or are already, stuck in snow, turn off VSA. It will conflict with your attempts.
Old Dec 28, 2008 | 09:13 AM
Registered Member
I also have a manual and I would highly recommend leaving it on most of the time under normal conditions since it offers a major safety feature.
Old Dec 28, 2008 | 10:27 AM
01tl4tl's Avatar
Consult your owner book for many features and systems that try to outdrive you on the TL
Traction control- ABS- speed sensing devices....
Practice with them NOW before they kick in sometime~
Old Dec 28, 2008 | 10:41 AM
paliknight's Avatar
i agree with the above posts. if your already stuck in snow, VSA wont help much because it wont let your tires spin to try and break free. but be aware of your surroundings when trying to break out of snow.
Old Dec 28, 2008 | 11:19 AM
Bearcat94's Avatar
AZ Community Team
Leave it on for normal day-to-day driving. The car it saves may be your own.
Besides, spinning tires is just wasting power and tire tread - you want power to propel you forward, no tkeep you sitting in the same place.
Old Dec 28, 2008 | 11:28 AM
MichaelBenz's Avatar
CTS-V Import Slayer
Pretty much agree fully with all accounts given. +1
Old Dec 28, 2008 | 12:37 PM
BEAR-AvHistory's Avatar
+2 Leave it on even with 6MT.
Old Dec 28, 2008 | 01:53 PM
mglax13's Avatar
New shoes on my
Does turning off the VSA, completely turn it off?
I ask this because I have a few friends with LX chassis Dodges (Magnum, Charger) and they mentioned that their version of the VSA is either On, or if switched off, is put into a less active mode, but still remains on. If they want to get it completely off, they need to mess around with the ECU. Apparently there are some other cars out there like this as well.
I personally don't turn the VSA off, except if I need to get out of the snow, or the one time I was curious if it really worked (it does).
Old Dec 29, 2008 | 12:22 AM
wall e's Avatar
TL=True Love
keep it off if u want to impress someone when u are at a redlight. keep it on for everyday driving.
Old Dec 29, 2008 | 07:11 AM
Registered Member
Yes, if you turn it off, it's off.
Old Dec 29, 2008 | 11:21 AM
Bearcat94's Avatar
AZ Community Team
:lol:
*Very* unlikely anybody I'd be interested in impressing is going to be sitting at the same light at the same time I am.
Maybe other people have a lot of people they need to impress?
Old Dec 29, 2008 | 07:05 PM
Nasty188's Avatar
Have A Nice Day!!!
I only take it off if I have to make a quick U turn or I will toggle with it if im stuck in the snow!
Old Dec 30, 2008 | 07:52 AM
Registered Member
Making a U-turn shouldn't make any difference unless you're in the habit of breaking traction when doing so.
Old Dec 30, 2008 | 09:17 PM
Nasty188's Avatar
Have A Nice Day!!!
Only if it's a hard U-turn I do
Old Dec 30, 2008 | 09:35 PM
ifirahse's Avatar
SlammedOnKonis
I leave it off when partaking in "spirited driving" (mountain runs, etc...)
Supposedly the SS shifts are crisper when VSA is off...
mada51589
Jan 9, 2025 04:40 PM
Jamus22
Jun 11, 2023 10:08 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
polish_pat
Sep 30, 2015 12:22 PM
